Case Study # 123 - Most Powerful Evo IX (so far) - 375 whp ! exhuast, intake & MBC!!
Quote:
Originally Posted by dakind916
What does crushing a bov mean?
To crush a bov (usually the 1 gen bov) you simply have to either use a vise to crush down the top hat of the bov, or use a hammer/wrench to push down the top of the bov. This will limit the amount of space for the diaphram inside the bov, thus helping to hold boost better...So, you are SLIGHTLY crushing/denting/ the top of the bov..
This does not work on all bov's
Originally Posted by 4TUN8
What is needed to swap to the 9 turbo?
Just get the 20g-9 which should produce even more power than the standerd 9 will..we will find out soon with the release of the 20g-9 in a couple of weeks..
Basically the 9 with simple mods is equivalent an 8 with same mods PLUS cams, alcohol, 20G.
The 8 was way overrated 03 and now from nowhere the 9 comes out with 150 extra HP with simple bolt ons. I'm going to go throw up, I fell sick
A stage1 IX with alcohol gives results that I am still currently modding for.
Wow, the new Evo seems almost too good to be true! I can't wait to see what happens as more people start adding cams, turboback and turn up the boost on their IXs. Good job Al, and
Originally Posted by kmcconn9
I dont know ig it is a direct swap or not. I beliebe Buschur said something about needing a different turbo outlet pipe since the 9 had a bigger compressor cover...This could have just been for his 20g-9 though.
so how much is that going to cost ya for a new turbo upgrade
If I got the 9 it would just have, TB, MBC, drop-in, alcohol, and of course DYNOFLASH custom tune. I would be content. The question I have is would DF be able to tune an 8 with a mivac head and ecu added.
[QUOTE=C6C6CH3vo]Basically the 9 with simple mods is equivalent an 8 with same mods PLUS cams, alcohol, 20G.
No it's hte 9 with simple mods is the equivalent of an 8 with same mods plus the 9 turbo and maybe cams. Why would the 9 turbo make more power than the 20G? The 20G is based of the 9 turbo. The Mivec head is more for lowend and midrange, not so much high end. It is mostly the turbo. So to rephrase your statement. The 9 is equivalent to and 8 with a 9 turbo swap, and maybe cams.
I don't even think alcohol should be included as you don't need to run higher boost if you are running the same turbo as the 9 or bigger.
Originally Posted by C6C6CH3vo
I don't think there is a cam upgrade option for mivac yet.
Anyways back on topic, these numbers are simply mind boggling. These numbers are made with the simplest of bolt on mods, probably stage 1 of a modified EVO.
Never would I have imagined that just an Intake, Cat-Back Exhaust
, Flash, and MBC could produce such impressive numbers (375WHP on 100oct), just imagine how much will be made with a full turboback/test pipe, my guess is that this car could see another 15-20WHP. Thats around 390WHP. Just imagine the possibilities. I know Cams are in the development, HKS, Precision Dyno, and a couple others are already working on them and should be releasing them in the near future. Right now IX is basically using parts more designed for the VIII (the fuel pump is a good example, a better fuel pump must be made for the IX or a fuel pump upgrade may not even be as necessary), and just imagine how much power will be made with parts designed just for the IX. Imagine the power that will be made on this car when it one day gets Cams, Cam Gears, FMIC, Intercooler piping, Injectors, better Fuel Pumps, Alcohol Kits, and etc.What amazes me also is the consistency, another EVO IX (Intake, MBC, and Flash) on the same dyno running similiar boost made an impressive 325WHP/360WTQ on pump gas. With a Cat-Back and 100oct, it too would produce similiar numbers as this IX. There seems to be a pattern arousing-
Flash/MBC/Exhaust/Intake= 330-350WHP (pump gas) Dyno Jet Flash/MBC/Exhaust/Intake= 370-390WHP (100oct) Dyno Jet
Flash/MBC/Exhaust/Intake= 290-310WHP (pump gas) Mustang or DD
Flash/MBC/Exhaust/Intake= 330-350WHP (100oct) Mustang or DD
These numbers come from what I have just been observing so far with all the different IX dynos, so it's up to you what you want to believe, but these are just my observations.
