DynoFlash [Visit Site]
Comp 272's and Custom Flash Done Today
Old Aug 20, 2006 | 04:48 PM
DynoFlash's Avatar
That is often the case however the car was tuned on the road.
Sometimes going uphil or down hill can effect the boost
But in this case the boost is really dropping on that car
Old Aug 23, 2006 | 05:49 AM
kapolani's Avatar
Originally Posted by DynoFlash
Thinking more about your problem . . . .
I would suggest a Forge adjustable wastegate actuator
After rulling out everything else a inproperlly set wastegate arm from the factory or a weat stock wastegate actuator srping is my diagnosis
I am a Forge dealer if you want to get one I can get it for you
Al
Al, I've been thinking about it and may go this route.
I've checked everything over and there are no leaks.
Question though - before I start buying parts and sticking it in my car - I'm curious if the stock wastegate can be adjusted. I want to do this as a quick test - to see if it makes a difference - if it does I'll go ahead and get the proper one.
Thanks.
By the way. The car is running great - even though you think it's weak - I've been eating up the domestics that seem to want to race me all the time.
The car purrs like a kitten even with the 272's. Your work is truly appreciated.
Thanks!
Old Aug 23, 2006 | 07:15 AM
DynoFlash's Avatar
Thanks.
Thanks!
You can adjust the stock actuator but IMHO the forge is the way to go Al
4dooradam
Jun 21, 2016 06:29 AM
nor11384
Jan 17, 2016 07:24 AM
90GSXDan
15
Jun 9, 2007 07:55 PM
rebelzx
Sep 9, 2004 09:54 PM
