DynoFlash [Visit Site]
Road Tuned than Dyno Proven
Old May 29, 2007 | 10:19 PM
Rollaway's Avatar
After getting bored from stock trim on my Evo IX (many evos later) I decided to get tuned... Met up with Al (DynoFlash) at "The Shop" in CT (bunch of great guys there)
due to it being late and being polite to the neighbors around the shop Al takes my car for a quick road tune... when he comes back my car gets strapped to the shop's DD dyno and this is the result
Mods are:
HKS RS Intake
HKS DLI
Maxford Header
Ebay o2 Housing
AMS FMIC
AMS LICP + UICP
QTP DP /w Electronic Cut-out
Whinebro 255lph
Perrin Test Pipe
also... for you westcoast guys its 93 octane that was used
Compared is the QTP DP w/ Electronic Cut-out opened vs closed
The test pipe was there previously before the QTP DP and I just left it there
Stock boost solenoid w/ pill removed and Road Tuned by Al (DynoFlash)
w/ cut-out closed it is at 20psi and opened it is at 23psi tapers to 17-18psi.. So I don't really need a bc
also worth mentioning is when compared closed vs open spoolup has around ~3-400rpm difference
Thanks to Al (DynoFlash) for the great road tune, Jim and the rest of the guys at "The Shop" for the quality service and Barry and the rest of quicktimeperformance.com for the great dp and cutout
Old May 29, 2007 | 10:37 PM
DynoFlash's Avatar
Thanks for posting that !
I have said many times - you can take a car tuned to perfection on the road and put it on any dyno and it will run really good - its always been the case
My butt dyno was off a bit as it felt like 325 whp to me - it was a fast car considering it was runnintg the stock ecu boost control
Thanks again
Al
Old May 30, 2007 | 01:46 PM
Rollaway's Avatar
Thanks again Al... when I get bored of the current setup I will be back for another tune when I decide to put more parts in
Old Jun 2, 2007 | 06:43 AM
kekek's Avatar
Perhaps boost control has to do with this....similar mods on this car here:
https://www.evolutionm.net/forums/sh...d.php?t=245912
His low end torque destroys your car. We're talking around 140 ft-lbs at 2950 rpm...thats HUGE. Your torque values look closer to an 8 than some of the 9's I've seen.
Any thoughts?
Old Jun 2, 2007 | 08:12 AM
DynoFlash's Avatar
Any thoughts?
Without a doubt running the factory boost control was a handicap on Gerrard's car
Adding a MBC would have allowed us to get a faster spool up and more tq down low ith a bit higher boost
AL
recompile
35
Aug 12, 2010 03:34 PM
HeRtYIXMR
17
May 13, 2008 12:09 PM
EVO8904
Nov 21, 2007 08:11 AM
fury656
55
Sep 5, 2006 06:30 PM
