Dyno Flash - tuned on Dyno Jet at ICS Evo IX With cams
I am kind of excited about this car as it is the first car I tuned at my new dyno facility - ICS
This car was a Stage II or III with stock fmic and cosworth cams on 93 octane pump gas
I really enjoyed being back on a dyno jet - this is the same one I have worked with several times at Top Speed in ATL and I ran it totally uncorrected
Its nice to have a even yard stick that "is what it is"
once again AL thanks for everything
car pulls really strong!
my last tune was @ the shop -> 327whp @ 22psi (dyno dynamics) = bad gas & my a/f was alittle rich.
today AL did 2 baseline pulls before he retuned my car it made 310whp @ 22psi
so im guessing that ics dynojet reads lower compare to the shop's dyno dynamics
anyway with new plugs, good gas and better a/f ratio my final run = 340whp/339wtq (30whp more)
well it all depends what correction they were using on the DD. 1.10... 1.15... 1.17.... 1.175...
it doesn't matter now... you got a baseline and then after the cams and tune you gained 30whp which is pretty impressive...
your car must feel great... you have max power from almost 6000rpm until ~7200rpm when you stopped the pull...
Al
The corrections are designed to level out variations in air temps and pressure on the dyno power production
The problem is that most of the standard corrections were designed for normally aspirated cars
Using SAE made the numbers a bit higher - I just left it uncorected
Al
