DynoFlash [Visit Site]
mbc vs ebc
Old Nov 13, 2007 | 08:19 PM
blueshark's Avatar
mbc vs ebc
hi al,
just wanted your opinion on which one you think is better. i will be getting a new boost controller very soon and since you are my tuner i wanted to ask you first. should i go with the aem tru-boost one or stay with a mbc? right now i have the forge type rs and it is the silver one which keeps giving me problems.
thanks,
omid.
Old Nov 14, 2007 | 06:51 AM
DynoFlash's Avatar
MBC all the way - Forge UNOS is my favorite
Old Nov 14, 2007 | 08:26 AM
ottomatic's Avatar
but don't you have to regularly clean out the forge in order for the spring to not get stuck?
Old Nov 14, 2007 | 12:13 PM
blueshark's Avatar
i got the silver one which i bought about two years ago. if i try to lower or upper the boost a little, the thing jumps up from 23 to 28-30 psi by just one or two clicks. its very frustrating so i dont know if i buy another forge would it keep acting the same way as the one i got???
thanks. omid.
Old Nov 18, 2007 | 06:44 PM
High_PSI's Avatar
I have the AEM Tru-Boost. Not only does it use a MAP Sensor (which is by far the most accurate) and not only does it set boost within decimals, it allows you to set the crack pressure for faster spoolup AND comes with a guage reading in PSI/BAR?other ones I don't use.
It also records your PEAK boost, it kicks ***, I like it better then my HALMAN MBC.
Old Nov 18, 2007 | 07:20 PM
Kc2Buk's Avatar
Don't POP the hood to change boot settings. Get an EBC
Old Nov 18, 2007 | 07:38 PM
cij911's Avatar
Al,
Can you please explain why you would NOT recommend the stock ECU to manage boost? And how could you recommend an MBC over an EBC? I would really love to understand your logic.
Old Dec 21, 2007 | 08:19 AM
SLO-EVO's Avatar
or get the cockpit setup for MBC!!!
Old Dec 21, 2007 | 08:38 AM
sillyrpm's Avatar
at first i was going to get a ebc until i talk to a tuner and he told me since i was going to used a aem ems it be better off just get a mbc save me some money too
Old Dec 21, 2007 | 05:40 PM
cij911's Avatar
LOL.....Why not use the AEM to control boost?????
