DynoFlash [Visit Site]
spark plugs
Old Feb 25, 2008 | 12:56 PM
blueshark's Avatar
spark plugs
hi guys,
just wanted to get some of your opinion on which spark plugs are the best. I have to change my plugs myself and i was wondering if you could tell me how to gap them. i know i have to buy the gapper but i have never used it before.
thanks.
Old Feb 25, 2008 | 01:15 PM
mike1023's Avatar
I run NGK BPR7ES and around .22-.25 gap. all depends on your setup and boost level.
Old Feb 25, 2008 | 01:20 PM
mitsuboost30's Avatar
How much boost are you running?
Old Feb 25, 2008 | 01:32 PM
mike1023's Avatar
21-22psi
I would say even with stock cars and you change plugs i would go with .22-.23
i have went throw a good around of plugs and always found that range to be the best for high and low boost levels.
Old Feb 25, 2008 | 02:03 PM
tony_b's Avatar
Gapping them is easy. Get yourself some feeler gauges and when they slide in without resistance, it's done.
If the opening is too wide out of the box, tap it down a little (lightly!!) and use the correct gauge to "open it up".
Old Feb 26, 2008 | 04:52 PM
blueshark's Avatar
i am running 21 psi and have the same spark plugs in currently so i will get the same ones(NGK BPR7ES)
Old Feb 26, 2008 | 04:53 PM
blueshark's Avatar
thank you all.
Old Feb 26, 2008 | 08:34 PM
DynoFlash's Avatar
I prefer the BR7ES also gapped around 24 for normal cars and 23 for alchy guys
Old Feb 26, 2008 | 09:49 PM
cfdfireman1's Avatar
10-4 Al, very rarely a misfire at 32 PSI stock ignition. And you can get them on eBay for a $1 a copy.
Old Feb 27, 2008 | 11:04 PM
blueshark's Avatar
ok good to see that you confirmed on that.
thanks.
Old Mar 7, 2008 | 05:43 PM
Endoe's Avatar
is it this kind...?
http://www.mfgsupply.com/m/c/BR7ES.html
snowmobile.....what is the different between BPR7ES and BR7ES...besides the "P"?
Old Mar 8, 2008 | 12:07 AM
blueshark's Avatar
thats what i want to know too!!
Old Mar 9, 2008 | 08:01 AM
DoughtCom's Avatar
I just got BPR7ES' yesterday and the freaking plug wires don't go all the way down! It's like the plugs are higher than the other ones. And when compared to the stock plugs the threaded part isn't as long so it's not going into the cylinder chamber as far?!
Old Mar 9, 2008 | 08:17 AM
SuPeRNeT's Avatar
You cant use these plugs in an evo9 dude you have to buy the irdiums ones..
The P stands for protruding tip.
Old Mar 9, 2008 | 08:24 AM
DoughtCom's Avatar
So all the people saying that they're running these plugs are wrong?
Lancershop sells the same exact ones for Evo's =/ http://www.lancershop.com/customer/p...?productid=169
I'm confused.
