DynoFlash [Visit Site]
4/10 & 4/11 SO CAL Dyno Flash tuning trip - time slot sign up !
Old Mar 2, 2004 | 11:37 AM
  #31
tama_mog's Avatar
Why dun you try www.z1auto.com
Adam will give you a good price on that hi flow cat, and delivers super quick (since I'm in SD, I know how fast it gets here).
Al, since rmr dp retains the stock location of the o2 sensor, theres no need to mess with the bong right? I wanted to clearify this b4 I go in for tuning. Thanks.
Old Mar 2, 2004 | 02:39 PM
  #32
DynoFlash's Avatar
I am more concerned about the rear 02 sesnor being in stock location and flush to the exhuast pipe as in stock situation
That is where we place the wideband o2 sesnsor during street tuning
Some exhausts such as UR have an extender pipe that puts it out 2 - 3 " - those are no good and they will need an extra bung welded on
Old Mar 2, 2004 | 05:10 PM
  #33
SinCityEvo's Avatar
Al, will our car throw a code since the sensor is removed during testing?
Old Mar 2, 2004 | 05:16 PM
  #34
DynoFlash's Avatar
yes - then we reset it at the end of the tune
Old Mar 2, 2004 | 05:44 PM
  #35
statix's Avatar
hey Al, put me down for 11:45 - 2:00, or somewhere in that area. I believe I'm #4 with deposits, thanks...
Old Mar 2, 2004 | 06:00 PM
  #36
tama_mog's Avatar
so....Al....from what you've said, I use rmr dp, rmr catback and UR high flow cat.... and it seems like from your description that I don't need the extra bung welded on....or am I wrong? I know you have experience with this exhaust set....so please advise....? =X
Old Mar 2, 2004 | 06:16 PM
  #37
DynoFlash's Avatar
rmr is fine
Old Mar 2, 2004 | 06:45 PM
  #38
tama_mog's Avatar
Thanks Al =)
Old Mar 2, 2004 | 07:06 PM
  #39
statix's Avatar
That would be on sunday, between 11:45-2:00, thanks...
Old Mar 2, 2004 | 09:12 PM
  #40
evov8's Avatar
Al, I have a Helix DP and HKS Cat-back and soon a UR High Flow. Will that be fine for the tune?
Old Mar 2, 2004 | 09:24 PM
  #41
DynoFlash's Avatar
You have to look at the rear o2 sensor bung and verify that it is flush against the exhuast pipe - and NOT exntended outwards
Old Mar 2, 2004 | 10:42 PM
  #42
SinCityEvo's Avatar
Well, my HKS Hi-power catback has the bung in the same OEM spot but protrudes out about an inch sort of like the original, meaning the threaded part of the bung is protruded out about an inch. Is that fine? The actual sensor nut when screwed in sits about an inch from the actual rounded pipe part.
I hope it's okay because i don't want to weld in another bung. I'm sure you have tuned Evos with HKS catbacks and you would know.
Old Mar 3, 2004 | 05:33 AM
  #43
DynoFlash's Avatar
no sweat man - as long as the o2 sesnor tip is in the exhuast flow
Old Mar 3, 2004 | 09:23 AM
  #44
SinCityEvo's Avatar
Cool. Any other things to go over and check on my car before I get there to make it easier?
Old Mar 3, 2004 | 09:28 AM
  #45
DynoFlash's Avatar
Make sure your car holds boost, runs decently and has a Walboro fuel pump 255 LPH
I would also suggest that your oil be resonably fresh
And most impornat - don;t use any off brand gas or buy it from a cheap gas station
I recomend buying gas at gas company owned gas stations which are as new as possible
Chevron seemed to be one of the best in LA when I was there
Costco whould be avoided at any cost
