DynoFlash [Visit Site]
AEM intake
Old Jun 24, 2004 | 02:17 PM
SSKILLA's Avatar
AEM intake
Hey AL ive been hearing that the aem intake freaks out the ecu and causes it to go lean.....does your flash fix this or should i dump the intake and go back to the stock intake pipe with the open air filter???...???
Old Jun 24, 2004 | 02:25 PM
lanevokai's Avatar
go back to stock that's what i did
Old Jun 24, 2004 | 02:30 PM
SSKILLA's Avatar
did u have a flash though?
Old Jun 24, 2004 | 02:37 PM
sr20det91's Avatar
A flash has nothing to do with how the air flows across the MAF sensor. IMO the only truly safe way to run the AEM intake is to run it in conjunction with their MAP conversion kit. I believe it comes with their stand-alone EMS system.
Old Jun 24, 2004 | 02:39 PM
SSKILLA's Avatar
but wont i loose hp if i go back to the stock intake boot???
Old Jun 24, 2004 | 03:27 PM
evo542's Avatar
maybe 10horses, but you don't habe to worry about blowing anything up
Old Jun 25, 2004 | 06:32 AM
SSKILLA's Avatar
hey al i got flashed for the aem intake....would putting the stock intake pipe with a cone affect my hp ratings or the ecu since it was flashed for the hard pipe??
Old Jun 25, 2004 | 06:33 AM
SSKILLA's Avatar
or will the HKS EIDS fix the problem??? i
Old Jun 25, 2004 | 09:22 AM
DynoFlash's Avatar
Every aftermarket intake set up will have an effect on the reading of the MAF sensor
What we do is to get these cars on the dyno and create fuel maps which work well with the particular intake to dial in a flat 11.1 / 1 a/f ratio
We have base maps for the following intakes:
1 - AEM
2 - HKS RS
3 - Buschur and Buschur with suction pipe
4 - K & N Drop in filter
5 - AMS
6 - ARC
7 - APexi
All you have to do when changing your intake is ship me the ecu along with the $100 upgrade fee and we install the new map to match your intake and other mods (The $100 fee is waived for those who had a custom tune)
IT IS IMPORTANT - that you do not change the intake on a Dyno Flash ecu without getting it upgraded
Thanks
jayevo23
Evo X How Tos / Installations
51
Nov 6, 2014 04:31 PM
Evo_Xela
May 29, 2014 11:30 AM
butters149
Apr 27, 2014 07:34 PM
alpinaturbo
14
Mar 2, 2014 12:02 PM
jasonetc
Apr 11, 2013 12:04 PM
