DynoFlash [Visit Site]
Random Misfire 0300: Dealership reflash available...
Old Jul 26, 2004 | 09:29 AM
Dr Evo's Avatar
Hi Al, I'm afraid to take my car to the dealer to get this done, will it erase my Dynoflash?
Old Jul 26, 2004 | 10:41 AM
Secret Chimp's Avatar
Yes it will erase your dynoflash. But you don't have to worry about the dealership noticing that you have a reflashed ecu when you go in to visit.
SC~
Old Jul 26, 2004 | 10:46 AM
DynoFlash's Avatar
SC~
Very soon I will have this reflash available here at Dyno Flash
ALL you will have to do is send in your ecu to me directly instead of the dealer and I will install the updated flash with the Dyno Flash for your car added !
The only problem here from what I see is that the new apparanetly DOES NOT work as promised to eliminate the 0300 misfire codes
Maybe some people who already had the code fixing flash can chime in ?
Old Jul 26, 2004 | 11:26 AM
MSanad's Avatar
So now all of a sudden Ur flash does NOT 100% Take care of that problem? go figure...
Old Jul 26, 2004 | 11:37 AM
DynoFlash's Avatar
Originally back a few months ago I was acting under the assumption that the Dyno Flash totally corrected the 0300 code issue that certain INDIVIDUAL evos have been having
The reason for this statement was based upon the fact that for 6 months we has never seen a 0300 code on a Dyno Flashed evo
Also - many users who had previously had the 0300 code issue reported that iyt went away after the DYno Flash was installed
Then - we stared to pick up some customers which had what I would desicribe as a sereve / cronic 0300 code issue who were looking to get a reflash to rid themselves of the code
On these cars we were able to significantly REDUCE the frequency and occurance of the 0300 code issue - however it became clear that the tuning alone was not the problem
At that point we revised our statement to indicate that the Dyno Flash significantly improved 0300 code issues in many cars but was not guaranteed to elminate the problem
Now the designed reflash is out and it also seems to be unable to correct the misfire code issue in several cars - at least that is what I have been told
Obviously - at this point the few cars that are afflicted with the frequent / severe / cronic misfire CAN NOT expect to see correction of the misfire 0300 code issue with the Dyno Flash - but they CAN expect to see improved perfromance and power with our reflash as can any other customer
I am working on getting the 0300 fix code and testing it to try and deterimine what if anything we can offer to help resolve this serious problem
I hope this clarifies issues for you
Old Jul 26, 2004 | 12:45 PM
MSanad's Avatar
As Far As I know I'm the only one with the what you call the "SEVERE CRONIC MISFIRE" and having the dynoflash Doesn't do anything for me, not even power i can't feel anything cause from gear 1 through 5 at 900RPM through whatever i can't drive i got to the point that I'd actually spend the money on the AEM to rid myself of the nonsense!
Old Jul 26, 2004 | 03:11 PM
DynoFlash's Avatar
You are close enough to me in Brooklyn - come by I will work on your car and try to make it better - I stand behind everything I do 100%
Old Jul 26, 2004 | 03:59 PM
MSanad's Avatar
Actually I'm in Atlanta Right now, I'm going to be here for some time... u swinging by any time soon?
Old Jul 29, 2004 | 01:49 PM
Toobs's Avatar
Al any update on this...
Thanks
Old Aug 18, 2004 | 01:47 AM
mitsuorder's Avatar
bump. Any new discoveries Al? My buddy's car has thrown this code from the get go. He has a mail in flash and is very interested in you efforts to alieviate this misfire code. Just recently he said that it has become worse.
Old Aug 22, 2004 | 02:59 PM
mitsuorder's Avatar
bump, anything?
