Attn Al: JUN 264 cam cards
bumping this up
.i want to buy 264 jun cams also before i drive down for a customflash.wondering if thats to much for the stock turbo/ecu.have you custom flash any jun set-ups with stock turbo/ecu?or should i stick with hks 264s with the stock ecu/turbo until i upgrade to a stand alone,and bigger turbo?
Originally Posted by evo81
bumping this up
The HKS 264 will get you almost as much power on the stock turbo and ecu as the JUN's can with a significantly better idel and driveability
HKS has basically designed a set up with its cams to provide maximum performance while mainatining excelent driveability on stock mass air flow sesnor and ecu
Like HKS USA rep once said to me - if bigger was always better - "we would make only 360 degree cams"
My advice is use the HKS 264 - 264 on anything with a mass air flow sesnor and stock ecu
Cars with stand alone use the JUN 264 /264
Cars that race with built motors and high rpms over 8000 get the JUN 272 / 272
airtreking
16
May 27, 2004 10:31 PM
until i get a stand alone
thanks for the reply
