Thanks RRE for Stage 1E (E85) 383whp/ 383 tq V5 Tephra mod
Old Jun 1, 2008 | 01:48 PM
evilution310's Avatar
Originally Posted by sEvoIXnTurboS2k
Confused? Me, no. You, maybe. A dynapack is the highest reading dyno. It reads about 10% higher than your average dynojet. I started off buy saying that the OP's dyno numbers of 383awhp on a dynapack is about 350awhp on a dynojet. Pretty respectable numbers. I then stated that my Evo made 350awhp on a dyno dynamics dynamometer with my current mods and 91 octane, and that with the soon to be installed AEM EMS and tuning on E-85 I fully expect to make at least 400awhp on a dyno dynamics dynamometer.
your making assumptions about a dyno you have never been on. Maybe other DD's you've heard of are like that but that one isnt. He would dyno well over 350whp on a dynojet, in fact evos that have dynoed on that DD have also dynoed on a local DJ and found the DJ reads about 20whp higher. But your in socal go to RRE with your wifeys IX and prove me wrong, I can tell you that most DD's Ive seen read very close to mustang dynos and its pretty much impossible to hit 350whp on a mustang dyno with stock turbo on 91. Maybe the DD your dynoing on reads a little higher than you think.
Old Jun 1, 2008 | 01:57 PM
1QYK9's Avatar
Originally Posted by evilution310
your making assumptions about a dyno you have never been on. Maybe other DD's you've heard of are like that but that one isnt. He would dyno well over 350whp on a dynojet, in fact evos that have dynoed on that DD have also dynoed on a local DJ and found the DJ reads about 20whp higher. But your in socal go to RRE with your wifeys IX and prove me wrong.
This is my last post concerning dyno's themselves. I have dyno'd many different cars on many different dynos. I can tell you that no dyno reads the same...meaning you could have two dynapacks at the same shop and you will get different readings on both. There are hundreds of threads on the Net talking about the differences between dynos and they all pretty much state the same thing--Mustang dynos and Dyno Dynamics Dynamometers read the lowest (hence why they are referred to as heartbreakers) and dynojets and dynapacks read the highest.
Old Jun 1, 2008 | 02:16 PM
SSP-Ralliart's Avatar
You do understand that the Dynapacks are a water break dyno right? Which means that they are the most accurate dyno around. Dynojets, Mustangs, etc.. are no where near as accurate. If you don't believe me then go to their site and question them. Don't assume about dynos without knowing how they opperate. Plus there is no tire slip on a dynapack.
Old Jun 1, 2008 | 02:18 PM
Plus like you said earlier no two dynos no matter if the same will throw the same numbers. very true.
Old Jun 1, 2008 | 02:22 PM
1QYK9's Avatar
I know a fair amount about dynapacks. Yes, I know that they are very accurate and are one of the most preferred dynos to tune on. But none of this addresses the fact that they read the highest out of any other dyno, and people simply need to under that.
Old Jun 1, 2008 | 03:17 PM
MO_EVO8's Avatar
Nice job!!
Old Jun 1, 2008 | 08:31 PM
skiracer's Avatar
The reason why E85 makes some crazy tq is because you can run more boost and timing. Boost and timing are what make torque. This same concept applies when you run MS109 or higher.
E85 is rated around 105 octane, but RRE's tuner thinks this gas behaves more like C16 since you can add a ton more timing compared to 105 unleaded race gas
Old Jun 1, 2008 | 08:32 PM
1QYK9's Avatar
That's great to know! Congrats again on some great gains!
Old Jun 1, 2008 | 08:41 PM
skiracer's Avatar
Rather focusing on the peak HP numbers for this dyno vs. that dyno, i think its more important to focus on the gains from my E85 vs. 91 octane tune with very basic mods on the car. Not too shabby for gas that's cheaper than 87 octane. Poor man's racegas!
+66whp gain on E85 ; 20% gain
+94 lbs torque gain on E85; 32% gain
Old Jun 1, 2008 | 08:44 PM
skiracer's Avatar
Congrats! That should translate to around 350awhp on a dynojet. What are your plans for future mods? I'd look at getting a 3" down-pipe vice a 2.75", and also some cams would help you out as well.
My wife has an Evo IX with a few more mods then yours; she made 350awhp on a dyno dynamics dynamometer on 91 octane at 23psi. We are adding an AEM EMS and are going to have it tuned on E-85. We are hoping for 400awhp!
Best of luck to you!
Awesome i heard Alan is doing a good job in San Deigo! You might want to consider using Scot for tuning since he's done a bunch of E85 tunes on AEM EMS already...
Old Jun 2, 2008 | 08:03 AM
1QYK9's Avatar
RRE charges $1000 to do tuning on AEM EMS'.
Old Jun 4, 2008 | 12:20 PM
Jim in Tucson's Avatar
Stock turbo/internals
I have a very basic Stage 1 Pkg all installed by RRE:
RC Engineering 1000cc injectors
Walbro fuel pump
Zeitronix stage Eleventeen
E85 stages can be found here:
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&topic=53637.0
skiracer,
You state that you have the RRE E85 Stage 1 with 1,000cc injectors.
In the E85 Stages thread RRE lists their Stage 1 as having 750cc injectors.
Please clarify.
What is a "Zeitronix stage Eleventeen"?
Thanks,
Jim
Old Jun 4, 2008 | 12:26 PM
Blizzackk's Avatar
holy crap almost 100 WTQ gained!, very sexy! It must pull very nicely. Glad your happy with your results
Old Jun 4, 2008 | 03:34 PM
1QYK9's Avatar
Originally Posted by Jim in Tucson
skiracer,
Please clarify.
Thanks,
Jim
I didn't think you could use 750cc injectors with E85. I thought 1000cc injectors were the minimum size?
Old Jun 4, 2008 | 04:07 PM
skiracer's Avatar
I think RRE just road tuned someone last week with Denso 720cc injectors and he was hitting around 90% injector duty cycle.
Zeitronix Stage Eleventeen is a RRE nickname for a Zeitronix that comes with all the sensors/displays, etc...
