Do you guys use colder plugs with E85?
Old Jul 13, 2008 | 12:30 PM
FlintownKilla's Avatar
Just wondering if you guys suggest using colder plugs or not with E85? If so where can I get some reasonably priced colder plugs for a 9?
Old Jul 13, 2008 | 12:47 PM
skiracer's Avatar
I use the OEM IX iridium equivalant plugs from NGK and seem to work for me
part# NGK ILFR7H
I get mine locally for $12/each here
http://www.roadraceengineering.com/evo.htm
Old Jul 13, 2008 | 11:48 PM
churchja's Avatar
Cooler plugs not recommended for E85
Since E85 burns cooler than standard gasoline, it is not recommended for E85... For C16 or other high octane gas most tuners would recommend you run colder plugs.
Just my 2 cents...
Old Jul 14, 2008 | 01:28 PM
mplspilot's Avatar
I suggest using colder plugs.
High boost>High cylinder pressures>High heat = need for a colder plug.
There's little reason for most people to not run colder plugs. Unless you use it as a daily driver putting a lot of miles and aren't running more than 21 psi and actually see them foul-up, I would just stick with a colder plug.
Old Jul 14, 2008 | 08:29 PM
Sounds good. I am planning on trying out some colder copper plugs to see how that works out
Old Jul 15, 2008 | 06:41 AM
merkzu's Avatar
There's no coppers for the IX, try denso IKH24. They are one step colder iridiums
chapscalyx
May 30, 2017 07:24 AM
Bmurray
E85 / Ethanol
11
Sep 6, 2016 01:18 PM
kyoo
Jun 25, 2016 12:10 PM
Ralli_Red
Mar 28, 2016 07:03 AM
Done
210
Apr 4, 2015 10:47 PM
