E85 hints and tips…
#166
So I've been messing with my E85 tune (switched on thurs) and I started out by leaning my map out to hit 12's during spool and WOT....I went and did a pull, put my info into VDR and my numbers for E85 came out lower than pump gas. My pump gas with cf of 1 is 271whp/296wtq while E85 was 252/262. I thought there was suppose to be gains from E85 straight from pump (even if minimal). Both pulls were same boost, but different places. Same timing map with different AFR's.
#168
Saw this in mrfred's E85 tuning notes that's why i asked.
#171
E85 itself is a heavy duty cleaner. Ever try using alcohol to clean something off?
If you want to clean your injectors, i highly recommend these guys:
http://www.rceng.com/Fuel-Injector-C...ajb3lsSogjJL24
#172
The whole benefit to E-85 is the fact that it has an octane rating (RON) of around 105 (depending on season and actual content of EtOH) With that heightened octane rating it has the ability to be run with much more timing. It also burns cooler for the motor, thus leading to happy, cooler EGTs, etc.
You must edit the timing map and then turn the wick up on the boost and then you will see the gains you want. This is the same for any type of race fuel you want to run. The whole advantage of them is the high octane, and the ability to run more timing and throw more boost at it. So, edit those tables and you'll be set. Just keep an eye on the AFR's keep them in the high 11's to mid 12's at WOT, and you will be alright.
#173
Unless you have a serious problem with injector gunk, then its not needed. There are some issues with gunk, but I am pretty sure that was from detergents used by the gas stations/companies that was used in their 93-87 octane they mixed with the E-100 on site (to make the final E-85) and it is not widespread. Just search around for a picture of a gas motor after X amount of miles, then a motor that has run on E-85 or ethanol after the same amount of miles. You will see what I mean.
#177
The "typical" peak timing I see goes something like this:
Stock turbo / FPgreen:
Evo 9 = 18-19*
Evo 8 = 22-23*
50trim / BBK / etc:
Evo 9 = 16-18*
Evo 8 = 18-20*
35R / FP3065 / etc:
Evo 9 = 14-15*
Evo 8 = 16-17*
Of course every Evo is different and keep in mind I am not listing boost pressure or mods.
here is another example showing average difference between 91 pump and E85 timing: (keep in mind boost pressure is almost always much higher on E85 as well)
Evo 9 = 18-19*
Evo 8 = 22-23*
50trim / BBK / etc:
Evo 9 = 16-18*
Evo 8 = 18-20*
35R / FP3065 / etc:
Evo 9 = 14-15*
Evo 8 = 16-17*
