Is a highflow Fuel Pump mandatory for E85?
Old Aug 14, 2008 | 01:15 AM
tephra's Avatar
as per subject... For E85:
I hate the whining noise of the walbro.. Figure if I can get away with using the stock IX pump then I will.
Thoughts?
Cheers
D.
Old Aug 14, 2008 | 01:34 AM
jroller's Avatar
My walbro isnt any louder than my OEM was. Youd never notice it unless you take the rear seat out. Its a super simple install and good insurance. Tunning with E-85 the minimal you need is a larger fuel pump. Many tuners ask that you install bigger injectors also.
Old Aug 14, 2008 | 02:01 AM
Cali2MDevo8's Avatar
Registered User
My walbro is noticable from outside the car. Most people on her recommend a double-pumper and 1000cc injc.
Old Aug 14, 2008 | 07:25 AM
Jim in Tucson's Avatar
Thoughts?
Cheers
D.
IX pump should work fine as long as you limit max boost to the appropriate IDCs and proper ARFs.
Old Aug 14, 2008 | 02:47 PM
[EVO]Cookie's Avatar
Dynamat can fix the noise but so can a little music....As for the pump you could on a stock motor stock turbo 25psi or less 1000cc injectors will put you right at 190lph at 8K. If you want the calculator I used just send me a PM.
Old Aug 15, 2008 | 04:42 PM
mrfred's Avatar
A high flow pump is needed unless you plan on limiting boost out at 6500 rpm (peak power rpm for stock turbo E85) to something like 20 psi, but what's the point in doing that with E85.
The Walbro really isn't that loud under normal conditions. I'm a real stickler about noise levels, and the only time I notice it during daily driving is when the car is idling at a stop. My understanding is that they can get temporarily noisy though when pushed for long periods of time at high boost.
If that's still too much noise for you, there are some drop-in Denso pumps that have almost as much flow capacity as a Walbro. There are a bit over 2x the cost though.
Old Aug 15, 2008 | 04:59 PM
skiracer's Avatar
My Walbro is decently quiet, but i also have the SSL leather interior. So, that might be quieting the pump more compared to the cloth interiors.
Old Aug 15, 2008 | 05:02 PM
The increased acceleration G's when running E85 will sufficiently distort your eardrum so that the sound of the Walbro will be entirely drowned out by your screams of glee.
BWAHAHAHA
Old Aug 15, 2008 | 08:22 PM
tephra's Avatar
Just outrun the sound right :P
Yeah I guess I will get a walbro.. Local place is charging $138 AUD for the FP walbro's.
Anyone want to send me a $69 US FP walbro? Can't imagine shipping will be more than $20
EvoEarl05
E85 / Ethanol
Apr 3, 2018 03:12 PM
LANEVOLIU
E85 / Ethanol
May 27, 2013 11:39 AM
silverIXMR
Northeast Region
Sep 6, 2012 08:35 PM
JdMeVo4
E85 / Ethanol
Mar 29, 2009 10:04 PM
AcePitcher11
32
Dec 26, 2008 03:33 PM
