E85 - First timer, observations on mpg.
Old Nov 17, 2008 | 05:02 PM
dan l's Avatar
Travman is getting hooked up with a set of FIC 1050's so we shall see if the problem persists after the injector swap. He is running PTE/FIC 850's right now. I'm on the same "style" 1000's in my DSM and I think I recall having part throttle popping in the terms of "yo dude, you have fire coming out the side of you car" due to my side exit exhaust. I'm sure its just a tuning thing and maybe the different style FIC's don't exhibit the same problem. We shall see.
If the problem persist on the new FIC 1050's well just do the gasolene+match+torch trick to the car and claim insurance. Well maybe travis won't do it but I'll slam a 12 pack and do it when he's not looking.
Old Nov 17, 2008 | 06:16 PM
FathouseFab's Avatar
Well good luck with it. I have pte 1200's for refereance.
Fathouse
Old Nov 18, 2008 | 07:30 AM
travman's Avatar
Originally Posted by dan l
I think they are partial throttle driving around and getting a rich condition causing a pop, not so much a backfire. Travman is just a little whiney ***** with sand in his vagina and it bothers him.
Yeah which I call a back-fire......sorry from now on I will call it a pop.
Originally Posted by travman
...not that I'm worried just an observation i was curious if anyone else had??
^ Yeah I am really whining about it......
Old Nov 18, 2008 | 07:43 AM
ROGERV's Avatar
I get about 17mpg normal driving city/hwy . Crazy driving I get about 14mpg.
Iam running Pte 1000cc injectors, My car does not backfire.
I was getting about 21-20 mpg normal driving city/hwy on 91 oct.
Old Nov 19, 2008 | 04:17 PM
mrfred's Avatar
- I get almost the exact same mileage in town and on the highway too.
- Every once in a while I get a "backfire" (they're not really backfires) if I touch the throttle during decel. Otherwise nothing. If you let off on the throttle from cruise, your injectors should be shutting off, so there should be no fuel to ignite in the exhaust. If you release the throttle from open loop, the injectors will continue to operate.
Old Nov 20, 2008 | 04:02 PM
dan l's Avatar
I think a liberal amount of sub 100% load partial throttle timing is what is needed to extend the gas mileage. That and adding in some EGR to reduce pumping losses should help out quite a bit while cruising. I do not get the part throttle pop, it might have something to do with the generous timing that I run. If I do get the pop, I just don't notice it. The car is very strong part throttling around town, very pleased.
Old Nov 20, 2008 | 04:36 PM
travman's Avatar
Mine occurs when I lift, shift to next gear and then get back on the gas it gets a pop out the exhaust (I refer to it as a back fire if/if not that is the correct terminology for it). I'm going to get my 1050's in soon they just arrived today but its to be 29 degrees here for the high and 3-6" of snow the next 2 days so I am def. holding off unil it warms up a tad...
Old Nov 20, 2008 | 05:16 PM
dan l's Avatar
Poor pookies hands hurt in the cold?
Old Nov 20, 2008 | 06:20 PM
travman's Avatar
**** yea dude.......I'm man enough to admit it.
Old Dec 1, 2008 | 08:07 AM
travman's Avatar
Update:
1050's went in this weekend (much easier w/ 2 hands and a garage thanks danl), used mrfreds latencies and scalings - everything is pretty much perfect (Thank you Mrfred). Those injectors are really nice, car runs extremely well now - that pop I was getting in between shifts at part throttle is now gone.
Re-tuned the fuel map and I'm running 11.8's from like 4000 rpms on - car loves it. I did a 1-4 gear pull after I had it dialed in the best I was going to get it that night and it took me 11.7 sec. to get from 11 mph to 108 mph. This included shifting and the slight delay waiting for the car to spool in 1st gear (didn't launch it). I got the info from my log seconds and took from where it went 100% tps in 1st to where i lifted in 4th at 7200 rpms. I had 1 count of knock in 1st gear and the rest was flat lined...Best part was smelling clutch at the top of 4th gear (held 23 psi all the way in 4th) - wonder how much longer the stocker will last? I am very much looking forward to gear based boost control
I am overall extremely pleased with the car.....I honestly don't think I can ever go back to 93 octane.
Old Dec 1, 2008 | 08:25 AM
dan l's Avatar
Yeah, mrfreds latencies are dead nuts on for 1050's and they also work for 1150's. The only other major adjustment is adding nearly 3x more fuel for cold cranking around the freezing mark.
The performance is seamless. I let an extremely picky car guy drive my evo on E85. He's the kind of person who can find faults in driveability of a stock evo, let alone one that has the power to spin third gear on a damp road. His impressions were how darn smooth things were and how much power their was. I think your doing something right when you ask the driver "how high were you revving it and how much boost was on the gauge". The driver replies "I don't know, I was glued to the road". This driver was only taking it to 6000rpm's, had no clue what speed he got it to (he got it to 120mph), and really didn't know what the boost was.
Trav, how is your gas mileage working out? I got 18mpg last tank really railing it hard.
Old Dec 1, 2008 | 09:27 AM
travman's Avatar
I got 17 mpg on the tank I filled up with in State College, that was with 30 miles of driving with 5 people in the car and going over the mt. on rt. 22 back to Pittsburgh - cant really complain about that. I don't see 19mpg being out of the question......Even on gasoline my mpg always suffered this time of year, I think it will approve once winter is over and the temps come back up.
Cold start this morning was one crank - it was about 35 degrees out, very nice. The warm start needs a little work, when it starts it gets a little blubbery and the rpms jump to like 1200 then fall to 500 then go up to my normal idle setting. I will get that squared away in time....
Yeah the car is ridiculously smooth......the 1050/1150 are a great injector.
Old Dec 1, 2008 | 09:49 AM
tkklemann's Avatar
Nice, I have the FIC 1050's too, and I don't get any popping or backfiring on decel in mine.
E85 is fun, and I think you are learning the same things about it I learned awhile ago with the mileage; There is no point in really "trying to conserve" it to get more miles out of a tank, so you just lay into it all the damn time like I do.
E85 has really made my car more forgiving, and much more fun to play with. I really feel as though I don't have to monitor the knock with a hawks eye nearly as much as I did before with regular gas.
Just make sure you start to tune the new maps that were found to help in start-up. I used Bryan's (razorlab) advice and added a ton more fuel to aid in start-up, and it helped tremendously.
And you are correct, the FIC 1050's seem to be a fantastic injector.
Old Dec 1, 2008 | 10:14 AM
travman's Avatar
Yeah the mileage doesn't change all that much from ripping on it to driving it normal......not as much as it did on gas, so I just have fun with it as much as I can.
On 93 it didn't matter what I did my car always was picky with knock and it was quite annoying. E85 has changed that completely - knock is almost non-existent and I find myself finally not having to care. I run like 7 deg. at peak and 17 deg by 7500 rpms, keeping it nice and conservative w/ 23/24 psi tapering to 21.5 at 7500.
Yeah I have been tweaking on those new maps since they were found, helped out a lot with cold starting and stuff.
Old Dec 1, 2008 | 10:36 AM
SpoolnupTuning's Avatar
My thoughts on this matter is unburnt E. We are running this stuff alot more richer than 93! If you notice the car will run fine on e85 on 93 map until you get into boost. Then your changing load, injector scaling and allot of other stuff and in the end your throwing allot more fuel at her!
