E85 - First timer, observations on mpg.
Old Dec 23, 2008 | 08:32 PM
  #31
RazorLab's Avatar
Originally Posted by SpoolnupTuning
My thoughts on this matter is unburnt E. We are running this stuff alot more richer than 93! If you notice the car will run fine on e85 on 93 map until you get into boost. Then your changing load, injector scaling and allot of other stuff and in the end your throwing allot more fuel at her!
You are confusing fuel volume with AFR. The scaling changes so that Stoich stays the same with the different fuel (E85) Stoich is Stoich is Stoich.
Closed loop with proper injector scaling uses fuel trims on E85 the same way it does on pump gas.
Old Jan 8, 2009 | 08:08 AM
  #32
SpoolnupTuning's Avatar
I know that! I was only quoting that backfire issue and I did say load change and you do not use load change in closed loop!
Old Jan 9, 2009 | 07:18 AM
  #33
travman's Avatar
Funny thing is I switched to FIC 1050's and that whole backfire/pop issue is gone..... I didn't change anything else, just injectors.
Old Jan 9, 2009 | 09:10 AM
  #34
probably was the latency's off a little then!
Old Jan 9, 2009 | 04:38 PM
  #35
dan l's Avatar
No! It was the same tuner every time! The latencies were where they should for good feedback conrol! Now do you see how ****ing annoying it is when people use exclamation points with every ****ing sentence! See how I did that! Even when I should be using a question mark I used an exclamation point! Are you perhaps related to Mike Huml!
Old Jan 9, 2009 | 04:56 PM
  #36
Creamo3's Avatar
Haha!! The backfiring fixed itself w/ new injectors!
Old Jan 9, 2009 | 11:34 PM
  #37
mplspilot's Avatar
Old Jan 10, 2009 | 12:56 AM
  #38
GST Motorsports's Avatar
load doesn't change in closed loop? That's news to me!
Old Jan 10, 2009 | 05:47 AM
  #39
tephra's Avatar
guys i get backfire all the time...
1050's + 93oct...
happens when in cruise overrun for a little bit then get back on the throttle quickly.. 25% of the time maybe
OR when im thrashing it and change gear it will pop as well...
Old Jan 10, 2009 | 06:42 PM
  #40
dan l's Avatar
Yeah I think injectors like the 1050's and 1150's don't like low PW action. They for sure aren't perfectly linear and have a drastic bit of nonlinearity at somewhere slightly below 1ms I've noticed. Unfortunately we spend a lot of time around there. I think the injectors also seem to suffer from a tick of hysteresis. I have no data, but just how they act. If you are going from high PW to sub 1ms PW they tend to go "rich" like they are opening/closing better than if you were say sitting and idling in a low PW state for a period of time. Oh well, I'm willing to live with it.
Old Jan 10, 2009 | 06:47 PM
  #41
silver3g2000's Avatar
Has anybody here had any longterm negative affects of using E-85? (ie corrosion etc)
Old Jan 10, 2009 | 09:33 PM
  #42
Jim in Tucson's Avatar
No.
Take a look at this thread: Who has been using E85 the longest.
gkswhdl88
Oct 14, 2015 08:34 PM
darkcoupon
Outlander Sport
15
Aug 28, 2013 06:24 PM
DeweyD
12
Aug 28, 2013 02:54 PM
03BoostedVIII
E85 / Ethanol
36
Aug 25, 2013 11:26 AM
Hardware
Aug 23, 2013 08:44 PM
