Unable to break 26psi
Old Nov 19, 2008 | 10:49 PM
bzzbee2's Avatar
I had a forge bov on mine.. It was horrible for DD so i went back to the Metal mitsu BOV.. i also upgraded the stock WG to a FP wastegate. It was a great choice!!!!
Old Nov 20, 2008 | 05:09 AM
lan_evo_mr9's Avatar
What's the best/safest method for 'crushing' the bov? Petey T, where do get the recirc tial? All I've seen are the open atmosphere ones. I think a buschur MBC and new or crushed bov is in my future. I was looking at bov's and it was hard to find some that will hold over 25psi.
Old Nov 20, 2008 | 05:15 AM
AF-Evo8's Avatar
http://www.tialsport.com/prod_bv_Aq.htm
Old Nov 20, 2008 | 06:01 AM
In order to use that beautiful tial I would have to get the v-band welded on to my upper IC pipe. Money is relatively tight right now and I'm looking for the cheapest way for a temporary solution to my issue. If that's what I have to do then that's what I have to do. Anyone tried the turboxs valves, especially the reversable one?
Old Nov 20, 2008 | 11:24 AM
PeteyTurbo's Avatar
Originally Posted by razorlab
The stock metal bov can hold boost.
You only hit 25 at the track because you where most likely 5500rpm + through the gears, on the roll on you where lower rpm.
I know my boost issues have to do with gearing and rpm at the track as well, but say if I set my boost for 27psi and go out on the highway, I can hear the BOV sound like it is almost surging after 25psi and letting air through even at lower RPM's..When I get a new BOV I am going to put the dyno in drag mode and do an overlay of my boost logs and see if it makes a difference..My guess is it will not but I still think it leaks..
Old Nov 20, 2008 | 11:41 AM
RazorLab's Avatar
yea it's probably leaking, crush it!
I had my personal evo tuned for 28psi peak, then I crushed the BOV and it hit 33-34psi peak with no other changes, which meant it was leaking the whole time.
Old Nov 20, 2008 | 12:30 PM
Do you just take a bell ping hammer to it, or a vice, or what other methods are there to crush safely? How far down do you crush from original height?
Old Nov 20, 2008 | 12:58 PM
oldevodude's Avatar
I saw a post on the internet where they used a vacuum gauge to measure opening vacuum pressure and then gradually crushed using a vice or Large c-clamp. I imagine if you crush too much the seam on top of bov could burst or maybe even too much spring pressure. Here is alternative method. I would like to know how these methods have worked for Evo drivers.
https://www.evolutionm.net/forums/sh...d.php?t=260029
thinking my stock 9 bov was not right I bought a used APS bov and it is not even holding 20psi
What about Synapse ? They claim 100 psi and use turbo sideconnection to hold valve closed
Old Nov 20, 2008 | 01:28 PM
Just crushed it pretty good and went for a drive. Same results. I'm definitely thinking boost controller now.
Old Nov 20, 2008 | 01:33 PM
RazorLab's Avatar
other alternative to crushing is the Dejon leak stop kit.
I've tuned a couple evos with it and they work great.
Towards the bottom of the page:
http://all.dejonpowerhouse.com/edit/A-04.htm
Old Nov 20, 2008 | 01:34 PM
PeteyTurbo's Avatar
It's already crushed but not all the way..Want something to laugh at?
Boost controll all the way in with a stiff spring..would spike over 30+psi with about 4 fewer turns from a roll..
Old Nov 20, 2008 | 01:37 PM
TxEvo8's Avatar
get a Forge RS. I had the same issue since I got a meth kit, the forge solved it.
Old Nov 20, 2008 | 03:49 PM
I just found a spring kit for the MBC on forge website for $15. I'll try the springs and if that doesn't work then it's definitely the BOV. Question- if I had shot throttle body shaft seals would my car be able to boost to this level of 25/26psi? Crap, I just realized the springs are for the BOV, not the MBC.
Old Nov 20, 2008 | 04:05 PM
evoix16's Avatar
Go with an HKS SSQ BOV its the best no resurculation required holds as much boost asyou can throw at it lol
Old Nov 20, 2008 | 04:21 PM
gotta have recirc
