E85 big injectors low idle Q
Old Aug 5, 2009 | 08:15 PM
94AWDcoupe's Avatar
Whats the largest injector I can run but still have nice 850-900 rpm idle?
Old Aug 5, 2009 | 08:25 PM
twabtoxer's Avatar
im running 1000s with the green turbo my idle is right around 900 rpm feels good. only when i run the ac, every so often i get like a hiccup lol at idle but never been an issue.
Old Aug 5, 2009 | 09:26 PM
Jim in Tucson's Avatar
Stock idle - 852 rpm - on RC 1,000cc injectors.
I have tweaked the idle up to 1,133 rpm when the A/C is on.
Old Aug 5, 2009 | 09:44 PM
skiracer's Avatar
RC 1000's here and idles just like stock...
Old Aug 6, 2009 | 12:09 AM
GST Motorsports's Avatar
So far 1450 BlueMax
I'm thinking of trying out a set of 1600's on my personal car just to conquer them on 91 oct (I know they work on E85) to say I did.
Old Aug 6, 2009 | 12:11 AM
GotWheelHop's Avatar
I have FIC 950's now and am planning on BlueMax 1650's so I can run serious boost.
My 950's idle amazing though.
Old Aug 6, 2009 | 01:27 AM
Yamahar1's Avatar
I'm running PTE 1200's and mine is at 900. With A/C on it's around 1200
Old Aug 6, 2009 | 05:41 AM
94AWDcoupe's Avatar
Hmm. wonder why you guys need to bump idle with a/c? my injector dynamic 1000 idle like stock at 850 with and without a/c. but I want to go bigger to 1200s. and my second car will need even more like 14--1600. GST how do the 1450 idle with a/c? do you think you can get bosch 1600s to idle low?
Old Aug 6, 2009 | 07:58 AM
travman's Avatar
Curious why not add a FPR and second fuel pump and crank your base pressure? the ID's are designed to work better at higher base pressures. At 100 psi they will work like a set of 1600's and you will still have outstanding idle quality and all the other benefits the ID's have over other injectors.
Old Aug 6, 2009 | 09:21 AM
tmiller's Avatar
I have the target idle set at 850, but it rarely get there. Most of the time it is @1000, and if it is hot it will hang at 1100-1200. I have RC 1000cc's. It does this on 91 pump as well. I have a mini battery, not sure is that is related...
Old Aug 6, 2009 | 09:46 AM
jid2's Avatar
My Bluemax 1450's idle fine on pump gas, it just took some swearing to get them scaled. I think my intake wasn't helping the issue as I did MAF scaling to get things working correctly.
Bryan try the 1600's I've always wondered if they would work on pump gas.
Old Aug 6, 2009 | 10:01 AM
94AWDcoupe's Avatar
the problem with that is fuel pump wont keep up at high boost. if I crank base to 50psi the fuel pump has to do that 50psi plus the boost psi 50+35=85psi. add in pressure loss through lines and filter and pump would need to be strong at 95psi.
Old Aug 6, 2009 | 10:12 AM
travman's Avatar
Yeah I know - just add an external pump (bosch) or a twin in-tank setup?
Old Aug 6, 2009 | 10:28 AM
Seemed fine when it rolled out of the shop (I always test A/C idle with aftermarket injectors.)
I've tuned a couple ID 1000's on the Evo 10's and so far I really like them.
Not sure on 1600's as I haven't touched them yet.
Old Aug 11, 2009 | 08:53 PM
mrfred's Avatar
My FIC 1050s idled just slightly choppy on pump gas. They flow 20-25% more than pretty much any other 1000 cc/min injector though.
