First fill up :)
Old Jun 6, 2010 | 10:48 AM
Zdrummer15's Avatar
It's absolutely worth switching, but there just aren't enough stations carrying it in some areas which sucks.
Old Jun 6, 2010 | 11:35 AM
LV///R's Avatar
Originally Posted by PlanoEvo
wow $1.89 I filled up last night at $2.39
Only a $1.79 now. Been like that for a bit now.
Old Jun 6, 2010 | 11:53 AM
Jim in Tucson's Avatar
Originally Posted by erald01
i am going to do the switch also BUT my only question is; did you empty the gas tank completle (drain it) or you can mix e85 with regular gasoline??? cause i am thinking of putting a switch for both maps e85 and 93 octane.
I make the switch once the red LOW FUEL light comes on. That is approx at 12 gals, so 2 still in the tank. Start it up, let it idle until it sounds different, then switch maps.
Now, if you are getting your car tuned, then you will want to run the tank dry, or simply wait until your 2nd tank of E85 and then get a tune.
Old Jun 14, 2010 | 04:34 AM
KaRboN's Avatar
What size injectors are you guys running for 550-600whp ? I have 1000cc now,And a few people said i should bump them up to 2100cc when switching to E85... What do you guys think.
And which brand injectors would you recommend -
Old Jun 14, 2010 | 08:27 AM
TheBoz's Avatar
You can make 600+ on 1350cc, you can make 700+ on 1600cc, on the 2150cc injectors I am at 70% dc and at 678whp on a dynojet.
Old Jun 14, 2010 | 08:41 AM
BlueEvo61106's Avatar
Wish we had Corn Fuel around us. The closest one to my area is over an hour away!!
Old Jun 14, 2010 | 08:46 AM
evolution2186's Avatar
The size of injectors depends on a few things. 1. How much boost? 2. What pump are you running?
Old Jun 14, 2010 | 03:37 PM
KaRboN's Avatar
Double pump setup,Not positive on sizes tho...I will have to ask sean - Boost will be at 35psi Most likely on E85...Currently its at 26 on pump
Maybe i will just get 1600cc's and call it a day then..I don't want to go past 650whp,That is my max for now which i wont even hit on the 35r ..
4G63kevin
May 3, 2010 05:13 AM
vvhiteix
39
Nov 18, 2008 07:50 AM
tripperfx3
11
Oct 8, 2007 04:45 PM
PDXEvo
Northwest Region
May 13, 2005 11:56 PM
bishiboy
21
Dec 21, 2004 03:00 PM
