Slipping clutch Q
Old Oct 6, 2007 | 12:55 AM
tripperfx3's Avatar
Slipping clutch Q
Just tonight it felt like my clutch starting to slip while trying to do some logs. I was just crusing in 5th and dropped it to 3rd and did a pull and it revved up like it was slipping, but then it was a hard engagement like i was launching the car, but while driving. It also didnt happen that often like it did when the clutch was going out with my old 240sx. I can take off from 1st (no launching. i have never launched my car as i have 50k on the stock clutch and wanted it to last until i had the money to get a new clutch) and go WOT and no slipping. I even went to 2nd, 3rd, and 4th WOT with no slipping problems. It only seemed to happen when in 5th and drop it into 3rd. It also only happened 3 times, but it does have me worried. I was thinking maybe i was actually losing traction (it was 35 degrees tonight). Any thoughts guys and gals?
Old Oct 6, 2007 | 02:54 AM
recompile's Avatar
I think most will agree that if you have 50k on the stock clutch and you are experiencing what feels like slipping, then you are probably slipping.
Start planning now, if you don't want to spend much, an ACT Heavy Duty Street would be perfect.
Old Oct 6, 2007 | 10:10 AM
tdz16's Avatar
50k on a stock clutch is impressive. I would definitely get ready to fork over some cash for an ACT.
Old Oct 6, 2007 | 10:45 AM
chaotichoax's Avatar
high gears = more load
soon enough you'll start slipping in lower gears too
new clutch time
Old Oct 6, 2007 | 10:53 AM
CrackerJackToy's Avatar
Yep, ive been running around on a slipping clutch for the past 6 weeks and mine did exactly that. Buy a new one.
Old Oct 6, 2007 | 10:57 AM
Max Speed's Avatar
my evo had a similar problem like yours but the only diffrent mine did it when i was in third and getting on it from a 2500 rpm all the way to red line and it felt like it started to slip at 5000rpm to about 5700rpm, then it will hook again, but it only did it maybe twice or 3 times. my evo is a ix with 3k on it and i have never launched the car, so i am almost sure its not the clutch, but in your case ill have to agree with every1 here man u got 50k on stock clutch, its about time for new1.
good luck
Old Oct 6, 2007 | 12:20 PM
tripperfx3's Avatar
Ehh... Crap... Thanks for all the replys and thats what i was afraid of. Ill just have to take it easy for now...
Old Oct 6, 2007 | 01:50 PM
tripperfx3's Avatar
Whats a good average for the labor for a clutch install? Ive been told around 500. Im defiently not going to the dealership around here, so it will be an independent shop.
Old Oct 6, 2007 | 02:11 PM
evo L's Avatar
the guy i know charges 600 for twin plate clutch installs, i dont know if single plate would be cheaper, but yeah 50k out of the stock clutch is great, be happy it lasted that long
Old Oct 6, 2007 | 02:15 PM
tripperfx3's Avatar
Thanks. I wish it would have lasted a bit longer though . I contacted the only local "performance car shop" in the Reno area and he wanted 995 !!! Then speedelement is only charging around 600, so i think it'd be worth it just to drive out there and get it done.
Old Oct 6, 2007 | 04:43 PM
ACTman's Avatar
Something to keep in mind on the EVO is that once the clutch starts to slip when it didn't before, it will degrade very rapidly to where you can't drive the car any longer so have your pennies saved up and parts on hand. It goes from bad to worse very quickly because there are stops built into the pressure plate that will prevent further travel (clamping) beyond a certain amount of wear, unlike most pressure plates that simply slowly go out of their normal working range. If it is starting to slip, it is probably because the disc is worn enough that the pressure plate is just touching the stops. Sorry to be the bearer of bad news.
Old Oct 8, 2007 | 04:45 PM
tripperfx3's Avatar
Not a problem and thanks for the input! Getting the car fixed in the next week or 2 with one of your ACT clutches!
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
Malik_EvoIX
Jan 14, 2009 09:19 AM
MyEvoRocksUrv8
14
Aug 23, 2008 01:10 AM
Jellyfishian
Lancer Tranny/Drivetrain Tech
Jan 13, 2008 08:16 PM
SRTRaceR04
Aug 18, 2007 01:26 AM
