Primer Cranking Enrichment-First Pulse-Max Value 255
Old Sep 15, 2010 | 07:54 AM
cheb evo's Avatar
Tried posting this under the ECUFlash Forum with no reponse, maybe it will be better received here...
I recently converted over to e85 and am experiencing some of the cold start issues that everyone has been describing on ROM ID 94170015. I am not currently running Tephra v7, however, I did add the xml definition need to display the Primer Cranking Enrichment Table, Post Primer Enrichment, and Post Primer Enrichment Decay in ECUFlash. The problem that I am having is the max value that I am able to put into the "units" blocks is 255 vs. the 360, etc. that you have used with great results.
My question is: how do I go beyond the 255 value in the Primer Cranking Enrichment-First Pulse table to allow for more IPW?
Old Sep 15, 2010 | 05:46 PM
mrfred's Avatar
Sounds like the definition is wrong.
Old Sep 16, 2010 | 07:18 AM
cheb evo's Avatar
Fred, this is the definition that I am currently using, and the only one that I have seen posted for ROM ID 94170015. Please let me know if you see something that needs to be updated/changed. Thanks!
<table name="Post Primer Enrich Decay #1" category="Fuel" address="3712" type="2D" level="2" scaling="EnrichmentAdj">
<table name="Engine Temp" address="67bc" type="X Axis" elements="9" scaling="Temp"/>
</table>
<table name="Post Primer Enrich Decay #2" category="Fuel" address="3722" type="2D" level="2" scaling="EnrichmentAdj">
</table>
<table name="Post Primer Enrich #1" category="Fuel" address="3732" type="2D" level="2" scaling="uint8">
</table>
<table name="Post Primer Enrich #2" category="Fuel" address="3742" type="2D" level="2" scaling="uint8">
</table>
<table name="Primer Cranking Enrich - First Pulse" category="Fuel" address="3810" type="2D" level="2" scaling="uint8">
<table name="Engine Temp" address="67d8" type="X Axis" elements="11" scaling="Temp"/>
</table>
Old Sep 16, 2010 | 07:30 AM
mrfred's Avatar
Those tables are all way out of date. Delete those tables and use these instead:
https://www.evolutionm.net/forums/ec...ml#post7639720
Old Sep 16, 2010 | 08:11 AM
cheb evo's Avatar
Thanks Fred. So, the tables the link directed me to are for 96530006, will this be compatible with my current ROM ID 94170015?
Old Sep 16, 2010 | 08:30 AM
mrfred's Avatar
Nope, they won't work. Sorry about that. For some reason I thought you had a 9653 ROM. I looked through the thread, and it appears that no one has ported the definitions to 94170015 yet.
Old Sep 16, 2010 | 09:22 AM
cheb evo's Avatar
No problem. I will play around with the table I currently have. Where I live, there is no way I will ever see temps in the -20F range, so having to go beyond 255 shouldn't be necessary. Thanks again!
Old Sep 16, 2010 | 02:43 PM
Jim in Tucson's Avatar
cheb,
I urge you to consider simply upgrading to a Tephra V7 ROM. I think this will solve your immediate needs and you will be much happier with the big maps and other Tephra enhancements.
I think you will find that upgrading to a fully enhanced ROM will be much easier than attempting to add particular enhancements to an old style ROM.
Jim
Old Sep 16, 2010 | 04:31 PM
cheb evo's Avatar
Thanks Jim, I really am considering jumping over to the v7, which I had briefly before I went to have my car professionally tuned on e85. The car drives so well right now on the current ROM, but I will certainly make the switch if cold start becomes a more serious issue.
Raceghost
Aug 10, 2018 10:39 PM
Benja
Jan 11, 2017 01:03 AM
audiofan
Oct 9, 2016 04:34 PM
mrfred
Oct 2, 2015 12:41 AM
Andy_8
Feb 12, 2011 12:34 AM
