Cold starts with e85 and a light weight battery
I'm looking into getting a light weight battery for my track car. The batteries with cca's close to my heavy OEM battery don't offer a lot of weight savings.
The lowest it gets around here is mid 20's, so I assume once the season starts I wouldn't be dealing with temps any worse than that hopefully. On these colder nights I have to crank 10-15 times to get the car going.
That said, are any of you guys out there getting away with a battery that has lower cca's than stock while running e85?
edit - This is for an STi, so tuning suggestions won't be of much help.
A lot of people have good results with this one
http://www.braillebattery.com/index....tteries/b3121/
550 CCA 1380 Pulse
21 Lbs and very small!
550 CCA 1380 Pulse
They are actually a bit better in the Subaru as they have multiple Cranking Fuel IPW Comp tables. MAP, Throttle, RPM, IAT and ECT.
I have both E85 and an small BATT, I have to start me car every day or i'll have to jump it. BTW the temp here only gets to low 30's(on average), it was worse when the temp dropped for those 2 weeks. I had trouble starting my car those two weeks it was in the teens.
As a comparison- pump grade gasolines run about 7.5-9 lbs RVP in summer and 12-15 lb RVP winter (varies by EPA/State regions). This is varied to make starting easier (and gas cheaper) in winter but lower boiling/ evap emissions in summer. Pure E98 has an RVP of 2.3 #.
I don't understand you guys with mini bat problems. I have min-bats in both my Mitsus and they are fine in teens to triple digits. Both on E85.
If I plan to have a car sit for more then a week or so, I disconnect the battery. But a couple days just sitting and it will still start up fine...
What mini-bats are you guys using?
Both my Mitsus see this in the winter and start up fine, E85 + mini-bat.
Wow. I am thankful for my Arizona weather. Where is this at?
06MREvo
43
Feb 3, 2011 10:38 PM
