Noob question about e85!
Old Mar 9, 2011 | 01:34 PM
suby2evo's Avatar
Right now i have an intake, full exhaust and tune on my evo 9. My question is about fueling, If I switch to e85 can I get away with the new aeromotive 340 pump and an aeromotive fuel regulator? or do I HAVE to upgrade injectors?
Thank You... flame suit on
Old Mar 9, 2011 | 08:45 PM
Jim in Tucson's Avatar
Originally Posted by suby2evo
... If I switch to e85 can I get away with the new aeromotive 340 pump and an aeromotive fuel regulator? or do I HAVE to upgrade injectors?
You will need 30% more fuel flowing out of your injectors. Period. Could that be achieved with higher pressure rather than more flow? Perhaps, but why would you want to break ground in uncharted territory when there are proven paths to E85 happiness?
Just sayin'.
Old Mar 10, 2011 | 06:48 AM
05blue8's Avatar
What Jim said. You can get a set of injectors for $2-300, do it the "right" way. It also depends on what your current duty cycle is on your injectors. I've seen logs where people run them to 110% + IDC but that isn't advisable. I'm not 100% positive on what the max is...120, 130, but at that point why risk blowing up your motor for $300 bucks? Wait and get the injectors too if you can't afford it all at once.
Old Mar 10, 2011 | 07:17 AM
suby2evo's Avatar
^^ Thanks guys, in that case I will just wait and get a set of 1000cc injectors. your responses are much appreciated
dookgvr4
Mar 24, 2017 06:23 AM
whiteEvo08Y
Mar 11, 2017 02:10 PM
CrazyLilPunk
Apr 24, 2016 04:17 PM
Steeldon
Apr 14, 2013 08:53 PM
catman78
E85 / Ethanol
10
Nov 7, 2011 05:47 AM
