Injector Reccomendation for 2.4 build
Old Jul 24, 2011 | 02:32 AM
catman78's Avatar
Hi all,
Putting together parts list for 2.4 E85 build.
Going to use my BBK Full for the moment.
I have a single Walbro with stock fuel rail.
Would FIC 1680 be enough and possibly swapping Walbro for Aeromotive?
Fuel Rail ?
thanks
Old Jul 24, 2011 | 12:29 PM
Angel Evo's Avatar
i got on my car 1450 cc 2 walbros one in the tank the other on the line who turn on with a pressure switch an a stock fuel rail an im making 497 hp on E-85 runinng realy safe on gas and i can put more boost
Old Jul 24, 2011 | 02:16 PM
catman78's Avatar
pressure switch automatic?
Are duals are usually run inline like that?
Thank for the input...
Old Jul 26, 2011 | 01:49 AM
catman78's Avatar
1250 CC Blue Max enough injector?
Old Jul 26, 2011 | 02:04 AM
SOEuro's Avatar
How much boost and what fuel??
Old Jul 26, 2011 | 03:01 AM
Mellon Racing's Avatar
a single walbro and fic 1450cc low z or 1680 high z should be sufficient UP TO 500awhp, beyond that it's time to do a big single like the aeromotive 340lph or better yet buschur twin walbro
Old Jul 26, 2011 | 10:41 AM
TheBoz's Avatar
Yep, run the High Z injectors, they are worth every penny, I think the same for the fuel pump.
Old Jul 26, 2011 | 12:39 PM
gkania's Avatar
1250cc will be enough for a BBK Full and single walbro. You would run out of pump before injector. Even with E85 you would not max 1250cc with that turbo. 1680 is overkill as well as many of these other suggestions.
Old Aug 6, 2011 | 03:05 AM
dscevo8's Avatar
1250s are enough....Im making 575hp and have plenty of injector left. I would suggest the 1450s though just because we were having trouble getting the 1250's to idle right for awhile. I did max the single wally at 500hp. I then just put in a buschur double pumper and was good to go
Old Nov 5, 2011 | 09:44 PM
chaosfiend21's Avatar
when do you think the id1000cc will not give any more fuel?
Old Nov 7, 2011 | 05:47 AM
on pump gas with a single walbro they should be good for up to 500awhp.
Black_EVO_MR
Oct 30, 2016 07:18 AM
ReivaXVrai2
18
Jun 22, 2016 11:30 AM
YFZracer32
Oct 19, 2015 12:03 PM
W2J
Mar 12, 2011 10:10 PM
djd24
Dec 16, 2006 12:53 PM
