Cold idle ?
Old Nov 2, 2011 | 05:17 AM
catman78's Avatar
Cold idle ?
Hi all,
getting cold up here and since this my first winter on E I wanted to address issue.
Start up is fine, however idle move up a bit then down a few times.
After around 20-30 seconds it will dip too low and stall. Kinda a PITA when I want to let the car warm up on it's own and go back in the house.
Should I be focusing on this table in V7
Idle Stepper Lookup table
If so, which areas should I be focusing on.
thanks
Old Nov 3, 2011 | 12:57 PM
escodotcarter's Avatar
What is your target idle set at with the colder temps? what does your timing look like in that area?
Old Nov 3, 2011 | 02:29 PM
catman78's Avatar
timing and desired idle neutral
Old Nov 3, 2011 | 04:52 PM
try lowering the timing in the 10-40 load areas between 1000-1500rpms. try like 5 or 7 and see if that helps.
Old Nov 3, 2011 | 06:05 PM
JohnBradley's Avatar
Timing keeps the idle up, idle rich (13.0), make sure you have the BISS set right. Idle at 1000-1200 warm, 2000 cold.
Dynotech Tuning
Sep 20, 2016 01:30 PM
Appauldd
Sep 21, 2015 08:39 AM
1fast97gsx
May 1, 2015 07:34 PM
Tbtalon94
AEM EMS
41
Feb 19, 2010 07:44 AM
Appauldd
Feb 23, 2009 08:05 PM
