correct injector size for hta35r on E85 setup
Old Nov 12, 2012 | 03:51 PM
gstturbo's Avatar
hello guys, I'm building a EVO8 with a 2.4L build motor and hta35r turbo setup and a full blown double Walbro 255 pump system. want to know the correct size of the injectors I should use for this E85 setup tuning on AEM EMS.thank you in advance for your answers
Old Nov 12, 2012 | 04:29 PM
bbyevo8u's Avatar
im using id2200 and they seem to be working great!
Old Nov 12, 2012 | 05:12 PM
This fuel forum is a bit sleepy. You should post up in the Engine forum for a better response
My .02 If your going to be running a larger turbo on E85 you should consider going big. Greater than 1200 / Probably 1600
Old Dec 1, 2012 | 12:13 PM
browningderek's Avatar
My injector duty was 88% at 43psi on fic 2150's
dscevo8
Nov 27, 2014 08:30 AM
triple L
Dec 30, 2012 10:03 AM
cdupont03
Jun 18, 2012 12:14 AM
MrHouse
30
Mar 25, 2010 02:12 PM
akunochi
E85 / Ethanol
Nov 18, 2007 04:02 PM
