Evo 8 With some Mods not quick enough but
Old Oct 21, 2013 | 07:48 AM
evonation99's Avatar
Hi Guys just bought my first evo and for some reason it feels like its lacking power...hence why i wanna go e85,its a evo 8 Jap spec with the following mods:
Apexi turbo back exhaust with high flow cat
plug and play ignition amp
apexi type r boost controller
injen air intake
bigger FMIC
coil overs
golpher alum radiater
so as you can see a few mods that should make it go quite good, it was in a small front ender when i bought it and the intercooler piping is abit restricted and the silicone hose connector has a couple of holes, they also reckon the intercooler is abit damaged could that be why its not that quick?
I have bought an intercooler and waiting for delivery so will see what happens.
im thinking of upgrading the injectors, putting a bigger fuel pump and remapping the ecu, or if i can get abit more money upgrade the ecu and run a dual map and tune it for e85, should that give me enough poke? and how much more should i be expecting?
Also would a 255 walbro fuel pump be sufficient , what injectors should i put, and whats a good mid priced/ranged ecu
Thanks for the future feedback
Old Oct 21, 2013 | 07:54 AM
rjfg's Avatar
Is it still stock ic pipingM
Old Oct 21, 2013 | 08:05 AM
heel2toe's Avatar
If you have holes in your intercooler piping/ couplers then that is certainly where I would start.
Before you start slapping on new parts get the car running right as is. You would be surprised how much of an affect a boost leak has on the engine. Have you ever tried to blow up a balloon with a hole in it? If so, how'd that work out for you
Old Oct 21, 2013 | 04:32 PM
It has after market piping. I just received the intercooler now but tossing as whether it will start raining when i put it on or not
Old Oct 21, 2013 | 04:33 PM
Yeah thats what im thinking, hopefully it makes a decent difference, as i think it has enough parts for now.
Old Oct 22, 2013 | 08:12 AM
http://i914.photobucket.com/albums/a...ps7d2e330d.jpg
http://i914.photobucket.com/albums/a...psbc69751f.jpg
Old Oct 22, 2013 | 08:14 AM
It has the injen intercooler piping/air intake...i attached pics of the damaged pipe, it was the lower RHS Intercooler pipe, looked pretty restrictive to me, the intercooler appears to be all good i filled it up with water and no leakage at all. so bought a ****ty intercooler and piping from ebay for no reason. all i needed was one or two pipes at most, never going to a "recommended' Mechanic again...
mr evo7
Jul 26, 2015 02:55 AM
evonation99
20
Oct 31, 2013 02:27 PM
recompile
Jul 11, 2013 07:49 AM
ZanarkO
Nov 20, 2010 10:28 AM
NIevo
Aug 12, 2007 05:45 PM
