e85 sitting for over a year
Old Nov 6, 2013 | 05:05 AM
usnevo8's Avatar
So in summer last year my engine gave out on me and at the current time i was running ethanol. Not sure how much was still in the tank but assuming the lines, walbro, and filter are still full will this be a problem when i get the new motor for gas or can it simply be drained and flushed somehow?
Old Nov 6, 2013 | 05:07 AM
REV.olution's Avatar
It'll be a problem for your fuel injectors. That's for sure. As for your inline filter, maybe. I'd drain that tank and put some 93 in with fuel injector cleaner ASAP. Good luck.
Old Nov 6, 2013 | 05:12 AM
usnevo8's Avatar
Well the engine I'm buying is a IX with everything including injectors but i was only curious about the tank and lines.
Old Nov 12, 2013 | 09:58 AM
I_want_MR's Avatar
To run E85, you need atleast 1000cc injectors. So I'm assuming that the engine you are buying has stock injectors. Therefore, you need to clean your current ones as i can safely assume that they are atleast 1,000cc
Old Nov 12, 2013 | 12:45 PM
usnevo8's Avatar
My current ones were 1450s. Im trying to go stock again and want sure if my filter or anything else could be ruined for 93 pump
Old Feb 8, 2014 | 04:07 PM
bennett124's Avatar
e85 does kind of gum up over time even during our Utah winter I put 91oct in my fuel and run it so its in the system so the e85 wont gum up as bad then start it ever few weeks to keep things moving in there. just what I do...
Old May 7, 2014 | 07:29 PM
Hoojan's Avatar
Same thing happened to a friend of mine. The car started and ran with the year old e85. He is going to clean the injectors before spirited driving.
Shiroi Kitsune
Jun 18, 2017 02:19 PM
JovanGee
Apr 26, 2017 08:27 AM
Hi Im Vinh
26
Dec 22, 2016 06:37 PM
_aye_
West Region
Jul 13, 2015 09:46 PM
Dus10
15
Oct 8, 2004 12:12 PM
