Need new injectors look for adevice that works
Well I've got a evo8 with a fp black, gsc s2 cams double pumper with a 2.0 motor. I'm wanting to switch to e85 and curious what size injector can make 600hp +. I've seen the 2150 bluwith max but there just way more expensive and some difficultime to tune I've heard. So is someone out there able to achieve that power with say a 1650cc or 1800cc and not have to jump to the 2150cc
FIC2150s are definitely more work to dial-in, but are otherwise the injector for making 750+ whp. FIC1650s or ASNU1500s are both purpose-made high flow injectors that are much easier to dial-in than FIC2150s and will support 650 whp without issue as long as the rest of the fuel system is up to the job. My personal exprience is that the ASNU1500s are the best injector that I've owned. I recommend them to anyone wanting to make 450-650 whp on E85.
Get some fic 1650 high z those are stainless steel. Now the 2150 are not so if you stop using the car and you ran E85 it can clog them every time you let the car sit run some pump 93 to prevent corrosion and rust
jdmdc2r01
Aug 29, 2012 09:38 AM
mexicanevo
West Region
Apr 26, 2007 02:05 PM
