Taking the plunge. Is this feasible?
Old Jul 12, 2017 | 08:13 PM
  #31
Originally Posted by N1MR0D
It kinda sounds like you guys are saying "go get the short list of bare minimum parts and get a tune and go enjoy it." Stop messing about!
Exactly, keep it simple to start. We all can have an engine build party down the road
Old Jul 12, 2017 | 08:15 PM
  #32
kaj's Avatar
kaj
It honestly depends on your
"money/time I want to put into it : fun " ratio.
​​​​​my car is down more than I drive it. Makes me want to sell. If I could go back and start over again...
Old Jul 13, 2017 | 05:26 AM
  #33
2006EvoIXer's Avatar
So I've read about speed density and MAF. I understand the concept between the two. At what point is it a consideration to move from MAF to speed density?
SD is a whole different animal for tuning. Do research to find the few who can truly tune it. That's the main reason why I stayed away, for now. From what I've read, there isn't many who can tune SD to run as good as MAF, let alone better.
Old Jul 13, 2017 | 01:49 PM
  #34
2winscroll's Avatar
SD tuning is not any harder than maf tuning IMO. Slightly more work, but not harder.
Stuff is not rocket science get your A/F correct then jack up the timing till it stops making power done. Same concept. With a non recirculated BOV car will run better on SD. E85 should net you easy over 400hp but you will need a 4 bar sensor with SD, or just stick with maf and tune for E85 would be the easiest.
Old Jul 13, 2017 | 08:18 PM
  #35
N1MR0D's Avatar
Well I bought some parts and have committed to speed density. We will see how it goes.
Time is more the problem. I don't have a lot of it to spare. I want to put more fun in to this. I don't get to enjoy her much anymore. My wife does. I do it for the pleasure of doing something I enjoy doing. But I understand. It's more fun to run the twisties than fight with rust.
THAT sounds like too much fun! I would love that!
Old Jul 13, 2017 | 09:24 PM
  #36
I'll grab a bag of popcorn and see how your tune goes. Lol
I've read too much complaints of tuners claiming to know how to tune for SD but car didn't run as smooth after the switch. Maybe the spent enough time in their base maps to fix this by now? GL and I hope it works out for you!
Old Jul 14, 2017 | 12:18 AM
  #37
kaj's Avatar
kaj
Links?
Old Jul 14, 2017 | 05:26 AM
  #38
stvn87903's Avatar
SD tunes have been around FOREVER for this platform. If a tuner can't tune SD, they probably shouldn't be tuning your car. I've had zero issues with my car being on speed density for the last 4 years. I have also not really seen anyone complain about it until now.
OP, one thing to note is you should, at the very least, get a AFR gauge. You'll need it for tuning purposes. And it's just a good thing to be able to visually monitor to make sure things are going well.
Old Jul 14, 2017 | 06:38 AM
  #39
Links?
I can't since it specifically names the tuners. I'll keep an eye out for the best local tuner.
Old Jul 14, 2017 | 11:51 AM
  #40
kaj's Avatar
kaj
You can't link other threads on this forum because it mentions specific tuners? Even though.. the threads... are... already on the forum...?
Old Jul 15, 2017 | 06:57 AM
  #41
Just trying to keep thread on positive side. ;-)
Just focus on getting OP to his planned power level.
Old Jul 15, 2017 | 09:57 AM
  #42
Jp7's Avatar
Jp7
**Edited** I just installed my HTA71 and just got tuned June 9th.
I do want more power but that means bigger turbo, and engine build (which won't be in my budget for another 10 years).
The hta71 is the perfect turbo for stock engine where we get best response that pushes the engine to it's limits. Many others have been saying this for years and they're right. Don't get me wrong. I love my hta71. I just want to beat the Hellcats on the track, but that will be expensive. Lol
Is your hta71 bigger than my hta3076r?
If so, I don't know why you would need more power. I have hta3076r with a Buschur built 2.3 and it scares the crap out of me with e85. I honestly can't use my lower gears wide-open throttle, it's just too much acceleration. I can get on it hard in 4th or higher but the mph is just too high to be safe.
I'm probably just a scaredy-cat driver but I don't understand how people go with these bigger turbos like the 3582 and such.
Old Jul 16, 2017 | 06:49 AM
  #43
kaj's Avatar
kaj
They don't care how the cars drive. They want them dyno numbers.
: lol:
Old Jul 17, 2017 | 10:59 PM
  #44
Hta71 is fast spooling turbo. It is linear (because of tuner), so it is very tamed. Not scary at all and very predictable. I think your 3076 is a bigger turbo sincr the hta71 actually has a 68mm **exducer**.
Your tuner should reduce the boost in lower gears *if* it is too scaryfor you.
Old Jul 17, 2017 | 11:06 PM
  #45
Jp7's Avatar
Jp7
Your tuner should reduce the boost in lower gears of it is too scaryfor you.
I probably just need to grow a set, and get more accustomed to it.
I only drive my car a few times a year so lack of practice makes it difficult to both enjoy or learn. I put about 150 miles on it in the last 2 weeks and that's more than I've done in a while. I had my engine built in summer 2014 and I only now going through my 3rd tank of e85. I've only probably been through about 500 miles or so since then.
