Help fitting flex fuel sensor to the fuel return line
Old Aug 2, 2018 | 12:01 PM
HyperDisorder's Avatar
At the moment, I am trying to figure out the easiest way to install my GM 13577429 flex fuel sensor to my fuel return line. As I understand it, the fuel return line is 1/4" and the hard lines on the sensor are 3/8". What is the easiest way to do this? I know that I could replace all of the 1/4" hose from the FPR through to the hard line with 8 fittings/adapters and 6AN line, but surely that is a bit excessive?
Is there something similar to
this this
that exists? This particular product is for nylon hoses though.
Alternatively, a couple of
these these
3/8 female to 6AN male adapters and couple of 6AN female to 1/4 male adapters similar to
these these
would work to adapt the flex fuel sensor size to hose size, but I just cannot find 1/4".
Cheers for any help!
Old Aug 2, 2018 | 12:08 PM
2006EvoIXer's Avatar
I bought a few quick connectors to adapt to the sensor's 3/8" To connect to 1/4" return hose. I'll need to go home and look for box.
Old Aug 2, 2018 | 12:12 PM
Jp7's Avatar
Jp7
You have the exact same problem I had. To see how I solved it, please check my thread. I chose to completely eliminate the stock return part of the rail. I think it was a cleaner solution.
https://www.evolutionm.net/forums/sh...3&postcount=40
Old Aug 2, 2018 | 12:28 PM
Here's a picture of the adaptor I used. This is probably the simplest option.
Old Aug 2, 2018 | 12:33 PM
I think I bought 2 of these to use.
Old Aug 2, 2018 | 12:52 PM
Wow, thanks guys, looks like problem solved. I'll go with 2006EvoIXer's solution first.
The next step of actually installing everything and tuning may be some time yet!
I'm in CA at the moment for work, so thought I'd pick up odds and ends that I still need while I'm in the US.
Eric SlowEvo8
Nov 13, 2017 05:25 AM
jrainwater
27
Jul 15, 2017 03:21 AM
06EvoIXmr07
Jun 20, 2016 08:01 PM
evoballer
Feb 15, 2012 06:49 AM
Hi Im Vinh
Oct 24, 2009 07:22 PM
