We need some "how to's"
Old May 12, 2006 | 08:46 AM
fsugatorbait's Avatar
Originally Posted by MalibuJack
Ihad the same thing happen, realized that I forgot to append .HEX or .ROM to the end of the filename when I saved it..
Find the file in explorer, rename it so it has a .hex or .bin at the end and you should see it.
+1.
Old May 12, 2006 | 02:16 PM
AlwaysinBoost's Avatar
Thanks to Malibujack & b0ostedEV08 for the help. I've got the correct files and everything is working like it should... I still haven't writen anything to my own ECU yet though.
I see now how easy it is to modify parameters but I would like to learn more about some of the descriptions before I mess with them.
Old May 12, 2006 | 02:26 PM
A very brief description of what each parameter does would be golden.
Old May 12, 2006 | 04:10 PM
Just enabled launch control and it works!
Does anyone know what "Boost Desired Engine Load 1-4" does? Is it maybe the stock boost solenoid controler?
Old May 15, 2006 | 09:04 PM
ScrappyJack's Avatar
Question
When I check the box to edit the field I get an error message that says: "the current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again."
For those receiving this error, what exactly do you want sent in? Just a copy of the .hex file? Do you need the ROM Identifier or any other information?
Old May 15, 2006 | 09:17 PM
b0ostedEV08's Avatar
Originally Posted by ScrappyJack
For those of us receiving this error, what exactly do you want us to send in? Just a copy of the .hex file? Do you need us to include the ROM Identifier or any other information?
Send your ROM to info@mynesperformance.com and year of your EVO.
Old May 15, 2006 | 11:00 PM
Noogles's Avatar
I'm workind on a detailed description of what each function does and an example of what chaging the map will do or what it could be used for. as soon as i'm done i'll post it up.
With the addition of the new release it might be a few more days.
Old May 15, 2006 | 11:23 PM
Thanks man! So I can focus on disassembling OBD II Subroutines
Old May 15, 2006 | 11:35 PM
Noogles's Avatar
You do the coding i'll do the usermanual.
Old May 16, 2006 | 04:49 AM
MalibuJack's Avatar
Let me know if you need any additional information, I'm always aquiring new data.. Noogles, do you want to do a Wiki for the user manual? PM Me and we'll set something up for them..
Old May 16, 2006 | 07:56 AM
Noogles's Avatar
Sure once i have a more complete draft, i'll e-mail it to you so you can take a look at it.
Old May 16, 2006 | 04:34 PM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
+1
Old May 17, 2006 | 01:31 PM
this would be DOPE!
Old Jun 18, 2006 | 05:38 PM
doublewide's Avatar
Has anyone answered you on this yet?
Old Jun 18, 2006 | 06:26 PM
from the different maps I've seen so far it looks like those selections are for controlling the stock boost solenoid.
