XML Defs (Updated for ECUFlash 1.27)
Old May 16, 2006 | 04:39 AM
MalibuJack's Avatar
Hey guys, I was sent these few new XML defs to evaluate and verify are okay, the scaling on them is fixed, but there are still a few tables left undefined, but I wanted to make sure the people who updated their ECUFlash to 1.27 had a current set of files..
unzip this file and drop the XML files into your rommetadata directory
(Default location is C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo )
If you altered any of your old files, copy them elsewhere first before overwriting them with these files. (back it up anyway if you feel like it)
** Just a word of warning, there are some new definitions that if altered can do serious damage to your engine if you do not understand what your doing.. So PLEASE understand what all these tables mean before altering them.**
File Type: zip
Old May 16, 2006 | 06:36 AM
donour's Avatar
Care you explain what the differences are supposed to be so I have an idea before I diff them? :-p
d
Old May 16, 2006 | 07:29 AM
MalibuJack's Avatar
I think there were some scaling issues in some of the defs, and one or two defs were missing..
Old May 16, 2006 | 08:54 AM
Noogles's Avatar
After looking at them last night and again today in the morning the Antilag Start/stop RPM are new but i was tired last night so i'm not sure.
Everything else is working well for me, I'm going to spend some time today working on the antilag feature.
Old May 16, 2006 | 09:19 AM
AlwaysinBoost's Avatar
I just copied over the new files but my scaling is still the same
Old May 16, 2006 | 09:23 AM
MalibuJack's Avatar
Post the ECU ID, its possible your ECU was one that wasn't updated..
I don't have ROM files for examples of every variant of the ECU (Internal ID) I keep finding new ones almost every day now..
702RSevo's Avatar
drag and droped the files into the 1.27 folder and nothing changed. but when i dropped them in the 1.26 folder got a whole bunch of new stuff but couldnt use it somthing about the maps.
Old May 16, 2006 | 09:27 AM
case ID: MN191022
Internal ID: 96420011
Old May 16, 2006 | 09:29 AM
MalibuJack's Avatar
Uninstall the old version.. You probably have two different installs but a shortcut to the old one..
Old May 16, 2006 | 09:36 AM
that was actually the first thing I thought of. But I checked under the HELP tab - About ECUFlash and it said version 1.27 created 5/15 @ 18:51:54
Old May 16, 2006 | 09:38 AM
MalibuJack's Avatar
Then the metadata directory is pointing to the old one (in the options section) I'm guessing it shares registry info..
Old May 16, 2006 | 09:45 AM
Noogles's Avatar
Removed to minimize potential damage
Old May 16, 2006 | 11:00 AM
702RSevo's Avatar
and how do u do that because they still dont work
Old May 16, 2006 | 11:15 AM
RazorLab's Avatar
under the options menu
Old May 16, 2006 | 01:50 PM
A418t81's Avatar
EDIT, of course I figured it out right after I posted this Program lost its path to the rom metadata folder. I still have the "problem" of not being able to see any of the new maps other than the knock filter even with Jack's updates added.
