XML Defs (Updated for ECUFlash 1.27)
Originally Posted by A418t81
EDIT, of course I figured it out right after I posted this
Program lost its path to the rom metadata folder. I still have the "problem" of not being able to see any of the new maps other than the knock filter even with Jack's updates added.
Program lost its path to the rom metadata folder. I still have the "problem" of not being able to see any of the new maps other than the knock filter even with Jack's updates added.Anyway, Its possible you stumbled on an ECU ID that has not had any updated Definitions yet.. You should E-mail your ROM to Jason so he can compare it to whats there.. My guess is either the mode your in is hiding some of them, or the XML file for your ECU doesn't have all the entry points.. I'm still finding new firmware ID's on a regular basis.. I think there were quite a few lots of ECU's produced, and within that, there were several rom updates for TSB issues and whatnot..
Jack
If you have 1.27 and 1.26 installed at the same time in two different locations, just uninstall both, delete the directories for both, then reinstall the newer one.. My guess is the directory your putting the files into is different than the location the program is looking..
Also, its possible that your program is set to "hide" invalid tables, and the access level may be set to beginner.. If you have a unique ECU to what has been provided or updated, then you will find some of the parameters are listed, but when you try to open them, they say their invalid..
If you have any issues with your rom, you should see what its "Internal ID" is, and post it here, its possible the definition for the specific rom is incomplete, or nonexistent.
I really can't support issues with the application, since its not my app, therefore you need to post the question in openECU.org if it goes beyond just a simple missing path or uninstall/reinstall issue..
What I do know is generally you should install new versions after uninstalling the old, if you cannot do that, then installing the new version over the old one replaces the program and old files. If that doesn't fix an application problem, then you have to ask the author of the program. If its ECU related, then you have to send a copy of your ROM to them so they can compare it to what they already have on file.
My user level was on Developer. I am still getting the problem though. It only happens on my own maps though. Maps I have of other people are scaled correctly.
Any ideas MalibuJack?
Can you e-mail me your map? (And let me know which ones read incorrectly) I'm hoping its just an old file that wasnt updated and your ECU is just unique to others.
For the 2005 ROM, 96940011, there are three invalid tables:
boost control limiting vehicle speed
max wastegate duty #4
boost desired engine load #4
If the addresses are the same as in other ROMS, then I can just fix it myself, but I wanted to post to make sure first.
Eric
Eric
Eric
Eric
boost control limiting vehicle speed: address 1E0A
Make sure you make this change to 96940011 XML and NOT evobase XML.
Originally Posted by b0ostedEV08
The 2005 EVO 8 ROM do not have the following tables:
Eric
mrfred
Feb 26, 2022 06:16 PM
