Unable to connect to vehicle interface?
Old May 25, 2006 | 05:39 PM
DynoFlash's Avatar
Its located at address 3ffce its a X X 01 number You simply mtach the one from your original map to any other maps you want to use
Old May 26, 2006 | 05:13 AM
Evil_1's Avatar
Thanks Al, would I be able to retreive this number with EcuFlash?
Old May 26, 2006 | 07:04 AM
donour's Avatar
Of course. It's one of the fields at the bottom. Download Ecuflash and check it out.
d
Old May 27, 2006 | 07:33 AM
awdmofo's Avatar
So you can use a map from a different year Evo 8 as long as you input your original immobilizer code?
Old May 28, 2006 | 03:02 PM
elhalisf's Avatar
i am still having trouble locating and chaning the immobilizer code. could someone post on how to locate it.
Old May 30, 2006 | 01:06 PM
evo 8 ya's Avatar
I couldn't find a 3ffce address but I did find a 3ffc0 address with a XX01 using Hex Workshop 4.2. Input please
Old May 30, 2006 | 03:03 PM
Warrtalon's Avatar
With your ROM open in EcuFlash, go down to the Misc section. Immobilizer is the first selection. Click on it to pop up the box showing your code. Click Edit>Copy. Then, open whatever other ROM you have, go to the same spot, open the Immobilizier and hit Edit>Paste. This will set the Immobilizer code to the same as the one from your car. I wasn't able to get the code to change by using (=) to set it directly, so I did copy/paste, which worked.
I used this on the Stock 05 ROM that can be found on the website, because I wanted a stock map and valet map. I took my modified-immobilizer Stock 05 ROM and changed the rev limiters for valet mode. I have not yet loaded these maps, though, because I wanted to make sure this was the right way to do it.
Old May 30, 2006 | 03:12 PM
elhalisf's Avatar
i dont see a immobilizer option under the misc tab. i downloaded a number of maps, and still couldn't see the immoblizer option
HELP
Old May 30, 2006 | 03:26 PM
Warrtalon's Avatar
Do you have version 1.26 or 1.27? I have the option under Misc with the 1.27 version. It's not based on the MAP - it's based on what parameters can be seen. Any map I look at has this selection.
Old May 30, 2006 | 03:31 PM
elhalisf's Avatar
1.27.658
any chance you can take a screen shot of it and post it.
and what do you mean when you say its not based on the map.
Old May 30, 2006 | 03:35 PM
elhalisf's Avatar
here is mine
http://www.mecah.com/faisal/desktop.jpg
Old May 30, 2006 | 04:02 PM
Warrtalon's Avatar
Originally Posted by elhalisf
1.27.658
I was referring to when you said you downloaded several maps and didn't see it. I'm saying that it doesn't matter how many maps you download - the Immobilizer is on every ROM, but you're not seeing it due to the software. When you downloaded 1.27 and installed it, did you also add the extra ROMMETADATA files that MalibuJack posted? That's my only guess...
Old May 30, 2006 | 04:22 PM
evo 8 ya's Avatar
I have 1.27 and I don't have "immobilizer" listed either
Old May 30, 2006 | 04:33 PM
elhalisf's Avatar
i got it
https://www.evolutionm.net/forums/sh...d.php?t=201369
thanx
Old May 30, 2006 | 04:37 PM
A418t81's Avatar
Access level wasn't it It defaults to beginner which will not show the immobilizer map and a host of others.
