post your maps here
Old Jul 4, 2006 | 12:26 PM
  #121
SuperHatch's Avatar
Originally Posted by mchuang
Pretty much Shiv just posted an ignition map of a car that had a flash that came to him to get tuned. He didnt mention any names he just posted a pic to show how timing should not be. It looked to be a pretty crappy timing map. It had 8's and 9 for timing in most of the boost portion above 140% between 3000 rpm to 5500 rpm. It pretty much look like at 14psi the car with that map was running 8 degrees of timing and when the car got to 20psi it was still running 8 degrees of timing, So it did not drop timing per psi of boost. Transitions from 1 load column to another were not smooth as there was no interpolation between columns.
Bingo!
Old Jul 4, 2006 | 12:36 PM
  #122
AlwaysinBoost's Avatar
after what I've learned in the last few weeks messing around with the EVOScan software and log reader I would NEVER put a generic 'base map' in my car. I honestly can't believe we don't here more stories of people blowing up. The only thing I can think of is either we have one hell of a strong engine from the factory or our knock protection in the stock ECU is excellent... come to think of it I'll bet its a combination of both.
Old Jul 4, 2006 | 12:40 PM
  #123
mchuang's Avatar
Originally Posted by elhalisf
He is offering flashes for $50 for god sake! I think he is actually doing the community a favor with that price.
Also, he has a reason for doing the high and low octane maps the same, and he was just backing that reasoning up. you see, with Al's flashes, his tune is safe enough that it will never switch to the low octane. when i put my WB with his flash on, the a/f numbers hit a max of 11.2 and was mostly at 10.5, and this was after adding a FMIC without updaing the tune.
i personally set both maps the same since i want to get the max performance all the time and i dont want to reset my battery every time i hit the track. the knock sensor does a good job, and i will leave it at that.
I remember reading (forgot where) before that it takes about 500 miles for the ecu to switch from the low octane to the high octane maps. But i know for sure that in the subies, they stay stuck in the low octane map, even when no knock is experienced for a long time. i dont want to experience the "oh my car is fast today"
As far as safe I think you are only refering to the fuel map since the car still runs pig rich, but as far as the timing map, I would have to disagree with you on that. You want to have smooth timing maps not big jumps. Also as a rule of thumb you are suppose to retard timing per psi of boost and then add back if the car likes it, which you will be able to tell on the dyno. Not just throw a bunch of the same number in 1 big portion of the boost map. It would be noticable if there was a way to show a 3d graph of ignition timing. Each to his own though. Just be careful and most of all have fun, I know I am
Old Jul 4, 2006 | 12:57 PM
  #124
Dayton_EVO's Avatar
+1
I've seen my tune from tuner "A" and I must say it is not good. Since we can't post up maps for review, I guess I will figure another avenue of sharing.
Old Jul 4, 2006 | 01:23 PM
  #125
Evo_Jay's Avatar
Originally Posted by Dayton_EVO
+1
Here is your other avenue...
There is already a website that has a library of ECUFlash maps.
Right now there is basically no EVO maps, but they have a vast librabry of Subaru maps.
We should start posting EVO maps there. You have to register to see/download/add maps.
http://www.osecuroms.org/
Old Jul 4, 2006 | 02:53 PM
  #126
gsrboi80's Avatar
Joined I wont post the map thats in my car now cause its not fair to Al to do so also upon buying it from him I agreed that I wouldnt. Im gonna do some loging and tweaking then Ill post it up.
Old Jul 4, 2006 | 03:24 PM
  #127
Roberto's Avatar
I would not post the "tweeked" maps either, unless they were completely different from what he sent.
Old Jul 4, 2006 | 03:58 PM
  #128
SuperHatch's Avatar
PM me a screenshot of the timing map, I will make a 3D representation of it. I will NOT put any values on the 3D plot, but the visualization would be excellent. I will do the same for a stock map and then we can compare the difference. This will in no way "share" the values, but it will help visualize the point being made here...
- Steve
Old Jul 6, 2006 | 01:34 AM
  #129
nj1266's Avatar
I agree with you on this. Your timing should start high, then go down with the onset of peak boost. At peak boost it should be in the low single digits and then climb up again to about 19-21 degree by redline.
something like this:
RPM, Timing, Airflow, O2
3070.0, 15.0, 9.83, 0.9
3238.0, 8.0, 13.46, 0.92
3453.0, 5.0, 18.18, 0.94
3746.0, 1.0, 23.01, 0.94
3953.0, 1.0, 23.3, 0.94
4227.0, 3.0, 23.7, 0.94
4508.0, 4.0, 24.49, 0.94
4781.0, 4.0, 26.82, 0.94
5012.0, 4.0, 28.34, 0.94
5258.0, 5.0, 29.36, 0.96
5512.0, 4.0, 30.04, 0.96
5738.0, 5.0, 31.18, 0.96
5938.0, 8.0, 32.09, 0.96
6168.0, 10.0, 33.13, 0.96
6379.0, 12.0, 33.31, 0.96
6566.0, 14.0, 33.21, 0.96
6781.0, 16.0, 33.0, 0.96
6965.0, 18.0, 32.8, 0.96
7129.0, 21.0, 31.85, 0.96
7316.0, 22.0, 32.58, 0.96
7309.0, 22.0, 32.33, 0.96
Old Jul 6, 2006 | 01:40 AM
  #130
elhalisf's Avatar
i think your timing until 6k rpm is WAY too low.
Old Jul 6, 2006 | 01:45 AM
  #131
nj1266's Avatar
The most likely period for the onset of detonation is in high boost conditions IIRC. Ad to that the crappy gas that we have in CA (**** poor 91 oct) and retarded timing is safe when you up the boost.
Old Jul 6, 2006 | 01:48 AM
  #132
elhalisf's Avatar
my bad, forgot about the 91 octane. but i think you should atleast start off at 5 degrees.
Old Jul 6, 2006 | 05:05 AM
  #133
honki24's Avatar
I think so too. The min. timing I have in my table is 3, and that is in one cell. the other lowest is 8. It runs on 93, but I really think 2 oct. points shouldnt make you use~5 deg. less. 5 deg is a noticeable change in power. very noticeable.
Old Jul 6, 2006 | 05:16 AM
  #134
honki24's Avatar
will someone please post a fresh, no alterations made, 03 ROM? I need a reference. (remember to get rid of your immob. code)
Old Jul 6, 2006 | 05:53 AM
  #135
justchil's Avatar
http://justchil.net/dl/evo/03Evo-Stock.bin
