2-step function
Old Jun 12, 2006 | 06:08 AM
MalibuJack's Avatar
A reflash "Standing rev limit" is not a true Two-step.. Its just referred to as such..
Old Jun 12, 2006 | 08:29 PM
Gruppe-S's Avatar
Actually it is true two-step, it's not a true anti-lag setup
Keep in mind that boost pressure will vary depending on which turbocharger you have. We are sitting our RPM a bit higher than 6K with the 20G turbo on the shop car. With a larger turbo you may even want to bump it higher. The 60' times are awesome but it is quite hard on the clutch! Our Gruppe-S Flash puts the limit in the low 6000's for stages 1/2 and higher for Stage 3 (GT3071)
Cheers,
Gary
Gruppe-S
Old Jun 13, 2006 | 03:56 AM
MalibuJack's Avatar
The anti-lag is a given.. I managed to put two thoughts together in the same sentence and may have been construed wrong.. I didn't mean in any way that the EVO had an anti-lag system for the US model, and the JDM/EUDM model has a Lean Spool system..
However, I looked up the two-step definition, and according to the current popular documentation, you are correct, the Evo's ECU does qualify as a two-step..
But my old drag race days, I had a two-step rev limiter which would step between two limits a few hundred RPM apart so you can stage for a long time..
Old Jun 13, 2006 | 05:41 AM
AlwaysinBoost's Avatar
while were on the subject... how long is too long to sit on the two step?
I've noticed the longer I sit the more boost builds but also my A/F goes in the very high teens.
Old Jun 13, 2006 | 08:50 AM
MalibuJack's Avatar
You shouldn't do it very long.. It wreaks havoc on the exhaust temps and coolant temps.. When you bracket or heads up race competatively you would occasionally get people who will play headgames while staging so you have to be ready... In reality, you should only do it long enough to quickly stage and launch..
Clipse3GT
44
Jan 29, 2022 09:54 PM
Oki Panoki
Jun 29, 2011 02:47 PM
warp9
May 8, 2008 07:10 PM
BOOSTEZ
20
May 19, 2006 03:55 PM
808MAUIBUILTEVO
AEM EMS
Jan 18, 2006 03:15 PM
