ECUFlash and TURBO Lancer
Old Jul 10, 2006 | 10:06 AM
  #31
Wallesasuaz's Avatar
I'll be in touch then...
Old Jul 10, 2006 | 01:09 PM
  #32
Z_Lancer_Man's Avatar
Originally Posted by MalibuJack
I think Lancer OZ will be your closest match to start with.. you should have a PM with my email address shortly..
Well, since I'm at work right now, I'll just send the ROM I saved using the EVO7 def. If you still want the ROM with the OZ def used, let me know and I'll pull that off the ECU this evening.
Old Jul 10, 2006 | 02:05 PM
  #33
MalibuJack's Avatar
The definition chosen is local to your machine, I should be able to use an OZ def when I open it later to work on it.
Old Jul 10, 2006 | 03:01 PM
  #34
Excellent, thanks!
Old Jul 10, 2006 | 03:55 PM
  #35
MalibuJack's Avatar
Looks like I'll have to go through the entire rom and find all the data segments and define them myself.. This may take a few days...
Old Jul 10, 2006 | 08:18 PM
  #36
awddyno's Avatar
thats what we were trying to do. I have some of the maps defined but not sure yet.
Old Jul 10, 2006 | 10:19 PM
  #37
Well, I've already been waiting almost 2 weeks....what's a few more days
Old Jul 13, 2006 | 10:34 AM
  #38
Any luck yet with the Lancer ROM?
Old Jul 13, 2006 | 12:47 PM
  #39
MalibuJack's Avatar
All the maps are in different locations so even though the Evo8 rom gave me some info, it was the wrong info.. I am not certain what maps do what.. I think we'll have to wait for someone to disassemble it, or if I get some time on a Turbo Lancer locally..
Old Jul 13, 2006 | 01:17 PM
  #40
Old Jul 13, 2006 | 03:09 PM
  #41
So what exactly is needing to be done? I really don't like waiting around for other people (though a really appreciate it) when there is something I can be doing as well. What is the basic jist of extracting the proper and creating the right definitions?
Old Jul 13, 2006 | 03:43 PM
  #42
MalibuJack's Avatar
The first half of the process involves disassembling the rom into assembly code or some other higher level language (IDAPro is what I use) so I can tell what is data and what is code, Unfortunately the hard part is once you find program data, figuring out what it is used for, and that requires step-tracing through some of the code to find where the program looks for it, and what it does.. Its not easy (I've been doing it for over a month now just on my own 03 evo rom) but its doable..
Its not rocket science, but it does require a bit of understanding of logic and programming (you don't ahve to be a programmer, just be able to understand what different code means)
Since I didn't have a complete list of memory addresses and functions associated with them (specifically for the hardware components like Digital I/O signal processors and analog I/O (drivers for relays or from sensor inputs) It made the job working with a fairly "unknown" ecu impossible.
What I could tell is that the Lancer ECU isn't all that different than the Evo ECU, but I need to physically see the two and their wiring diagrams and pinouts to see how similar they actually are.
Anyway, I hate to say this, but there's little more I can do at the moment until I can disassemble the rom, and I don't think my current schedule will permit that much time to work on it.
Old Jul 13, 2006 | 03:49 PM
  #43
MalibuJack's Avatar
It looks like there are a few tuners out there who know a bit about reflashing the Lancer ECU, Ripp Mods, and RRE are two you can contact, Jason at Mynes is also a great resource since he has alot of experience doing this already, but he's busy and he isn't getting paid for the contributions he's made so understand if he can't get to it right away (if Ever)
The good news is there are TONS of programmers on this forum, and elsewhere, that are probably already taking the code apart to see how it works, and even to modify it to do new and wonderful things.. So Its really only a matter of time before all of this is documented. Understand that this is a revolutionary paradigm shift in the Mitsubishi world, a few months ago, it was thought that this wasn't even possible for someone like us to modify our ECU's parameters, let alone it was thought to be impossible to retrieve the rom Intact without destroying the ECU it came from...
Old Jul 13, 2006 | 04:09 PM
  #44
Thanks for the explanation. For what its worth - the 02, 03 Lancer ECU pinout is the same as the EVO pinout. At least the 03,04 EVO. RRE has confirmed that as well as others who use the EVO pinout diagrams for wiring a Greddy eManage to the Lancer ECU harness.
Jason at Mynes took my ROM about 3 weeks ago to work on it, but like you said, he's plenty busy and I'm sure figuring out the Lancer map isn't a high priority. I might just have to start this all myself. I have plenty of programming experience so figuring out code isn't a problem for me. Thanks again for your help and we'll see what else can be done.
Old Jul 24, 2006 | 07:14 AM
  #45
Lancerguy'03's Avatar
this sucks.....so i guess i wasted the money on the cable....but from what post #4 and #5 say is that not ture???? this kinda pisses me off cause i was under the impression this was goin to work for our cars...reading the posts and other stuff and what not.....hope this works out soon.
