evoscan logger release
Old Jun 29, 2006 | 07:06 PM
  #136
EvO8yOuZ's Avatar
then where do you find it??
Old Jun 29, 2006 | 07:09 PM
  #137
justchil's Avatar
C:\Program Files\EvoScan\EvoScan v0.7\SavedDataLogs
For those who missed it Make a shortcut on your desktop for it.
Old Jun 29, 2006 | 07:15 PM
  #138
Z_Lancer_Man's Avatar
I posted this over in openecu.org as well - let me know what you guy think....
Originally Posted by Second Chance
Thought this might help some, it needs ALOT more work. Feedback is welcome.
Needs .NET 2.0 framework
Mad If I could get your code, i'd like to make just a basic console logging program so I can try and get more speed in the logging department without all the updates etc.
So I downloaded this program and tried it out. First of all, it works great - at least I think so Here are the two pulls I recorded. Unfortunately, I have quite a bit of knock which is what I was afraid of..... :cry: Now if they can only get the definitions right for my ECU and I can make some changes with ECUFlash 8)
Run #1 from 3rd gear
Run #2 from 2nd gear
Old Jun 29, 2006 | 08:19 PM
  #139
Ludikraut's Avatar
Nice looking graph, but the numbers don't seem to make sense. Were you @ WOT during the pull(s)?
l8r)
Old Jun 29, 2006 | 09:40 PM
  #140
Well, come to think of it, I don't think I had the throttle smashed to the floor, but maybe I did..... According to the plot though my throttle position is varying.....
Old Jul 1, 2006 | 07:48 PM
  #141
Spooldyou's Avatar
If its still rough values, than i think i will wait till the next version, im not one to be a lab rat.
Old Jul 1, 2006 | 08:13 PM
  #142
andenbre's Avatar
my throttle logs read very accuratly
Old Jul 2, 2006 | 06:10 AM
  #143
AlwaysinBoost's Avatar
If I'm reading your log right you're getting some SERIOUS knock. You want to tune it so that line at the bottom (knock sum) is totally flat. Below is a log from yesterday with a 2nd - 4th gear pull. Notice how there is virtually no presence of knock, that is what oyu want to shoot for.
Old Jul 2, 2006 | 09:19 AM
  #144
jcsbanks's Avatar
I have been suspecting for some time that the high timing numbers being thrown about on here would never be tolerated on my IX on Euro 98 RON fuel without detonation when you beat on the car... Maybe I run a bit more boost than many, but I also won't tolerate any detonation, many do, I treat it like the plague.
Old Jul 2, 2006 | 11:40 AM
  #145
I was afraid of that - I know I'm getting WAY too much. I've been waiting for the definitions to be made for my ECU so I can use ECUFlash, but so far, no one has been able to extract my maps from my ROM. Till then I guess I'll just have to stay off the boost since I obviously don't want to destroy my engine.
Old Jul 2, 2006 | 12:04 PM
  #146
I would turn your boost down to static pressure and stay out of it until you can adjust your tune.
Old Jul 2, 2006 | 12:27 PM
  #147
dudical26's Avatar
Is there any way to log boost with this program?
Old Jul 2, 2006 | 02:10 PM
  #148
Adding WB data and boost logging capabality will make this one heck of a program... I'm sure those two features are just around the corner!
Old Jul 2, 2006 | 02:47 PM
  #149
Cannonballer's Avatar
Wouldn't boost logging require the installation of an additional sensor of some sort? I was under the impression the stock ecu had no idea what actual boost was, instead it used an calculation of some sort to approximate...
Old Jul 2, 2006 | 03:28 PM
  #150
andenbre's Avatar
what is the pressure sensor in the intake manifold used for? there is a atmostpheric press sensor in the maf and a map sensor in the intake.
