Read from ECU window is blank...
Old Jul 6, 2006 | 02:37 PM
MalibuJack's Avatar
C:/Program Files/OpenECU/EcuFlash/rommetadata
Just put that in under options, Metadata Directory..
If you drilled down to Evo, it won't work right..
Old Jul 6, 2006 | 05:39 PM
ez's Avatar
ez
That solved it...thank you Jack!
But now I get an error that stops the read. Has this issue been addressed in another thread?
[12:58:02.676] Version 1.28.716
[12:58:02.956] 8 memory models read.
[12:58:17.357] 71 ROM metadata models read.
[12:58:17.357] checksum module "subarudbw" loaded.
[12:58:17.407] flashing tool "wrx02" loaded.
[12:58:17.467] flashing tool "wrx04" loaded.
[12:58:17.467] flashing tool "sti04" loaded.
[12:58:17.467] flashing tool "sti05" loaded.
[12:58:17.527] flashing tool "mitsukernel" loaded.
[12:58:17.537] flashing tool "mitsukernelocp" loaded.
[12:58:17.587] flashing tool "mitsubootloader" loaded.
[12:58:56.143] sending init sequence 1 (0001)
[12:58:57.174] got 0x05 response
[12:58:57.204] sending init sequence 2
[12:58:57.224] got 0x1B response
[12:58:57.254] sending init sequence 3
[12:58:57.685] entering bootloader
[12:58:57.725] sending kernel size (3392)
[12:58:57.785] sending kernel load address (0xFFFF8800)
[12:58:57.875] uploading kernel
[12:58:58.466] verifying kernel checksum response
[12:58:58.496] kernel valid
[12:58:58.716] kernel get version
[12:58:58.766] kernel version is : OpenECU Mitsubishi SH7052 Kernel V0.21
[12:58:58.876] Dumping ECU memory...
[12:58:59.097] kernel read area: addr: 00000000 len: 0400
[12:58:59.277] kernel read area: addr: 00000400 len: 0400
[12:58:59.467] kernel read area: addr: 00000800 len: 0400
[12:58:59.718] kernel read area: addr: 00000C00 len: 0400
[12:59:00.028] kernel read area: addr: 00001000 len: 0400
[12:59:00.268] kernel read area: addr: 00001400 len: 0400
[12:59:00.539] kernel read area: addr: 00001800 len: 0400
[12:59:00.799] kernel read area: addr: 00001C00 len: 0400
[12:59:01.070] kernel read area: addr: 00002000 len: 0400
[12:59:01.350] kernel read area: addr: 00002400 len: 0400
[12:59:01.620] kernel read area: addr: 00002800 len: 0400
[12:59:01.931] kernel read area: addr: 00003000 len: 0400
[12:59:02.191] kernel read area: addr: 00003400 len: 0400
[12:59:02.512] kernel read area: addr: 00003800 len: 0400
[12:59:02.682] kernel read area: addr: 00003C00 len: 0400
[12:59:02.892] kernel read area: addr: 00004000 len: 0400
[12:59:03.062] kernel read area: addr: 00004400 len: 0400
[12:59:03.313] kernel read area: addr: 00004800 len: 0400
[12:59:03.523] kernel read area: addr: 00004C00 len: 0400
[12:59:03.713] kernel read area: addr: 00005000 len: 0400
[12:59:03.914] kernel read area: addr: 00005400 len: 0400
[12:59:04.124] kernel read area: addr: 00005800 len: 0400
[12:59:04.324] kernel read area: addr: 00005C00 len: 0400
[12:59:04.525] kernel read area: addr: 00006000 len: 0400
[12:59:04.655] kernel read area: addr: 00006400 len: 0400
[12:59:04.905] kernel read area: addr: 00006800 len: 0400
[12:59:05.075] kernel read area: addr: 00006C00 len: 0400
[12:59:05.256] kernel read area: addr: 00007000 len: 0400
[12:59:05.446] kernel read area: addr: 00007400 len: 0400
[12:59:05.616] kernel read area: addr: 00007800 len: 0400
[12:59:05.826] kernel read area: addr: 00008000 len: 0400
[12:59:06.027] kernel read area: addr: 00008400 len: 0400
[12:59:06.217] kernel read area: addr: 00008800 len: 0400
[12:59:06.427] kernel read area: addr: 00008C00 len: 0400
[12:59:06.608] kernel read area: addr: 00009000 len: 0400
[12:59:06.808] kernel read area: addr: 00009400 len: 0400
[12:59:07.008] kernel read area: addr: 00009800 len: 0400
[12:59:07.208] kernel read area: addr: 00009C00 len: 0400
[12:59:07.419] kernel read area: addr: 0000A000 len: 0400
[12:59:07.619] kernel read area: addr: 0000A400 len: 0400
[12:59:07.809] kernel read area: addr: 0000A800 len: 0400
[12:59:08.010] kernel read area: addr: 0000AC00 len: 0400
[12:59:08.210] kernel read area: addr: 0000B000 len: 0400
[12:59:08.400] kernel read area: addr: 0000B400 len: 0400
[12:59:08.610] kernel read area: addr: 0000B800 len: 0400
[12:59:08.781] kernel read area: addr: 0000BC00 len: 0400
[12:59:08.981] kernel read area: addr: 0000C000 len: 0400
[12:59:09.181] kernel read area: addr: 0000C400 len: 0400
[12:59:09.412] kernel read area: addr: 0000C800 len: 0400
[12:59:09.612] kernel read area: addr: 0000CC00 len: 0400
[12:59:09.832] kernel read area: addr: 0000D000 len: 0400
[12:59:10.022] kernel read area: addr: 0000D400 len: 0400
[12:59:10.133] kernel read area: addr: 0000D800 len: 0400
[12:59:10.323] kernel read area: addr: 0000DC00 len: 0400
[12:59:10.523] kernel read area: addr: 0000E000 len: 0400
[12:59:10.723] kernel read area: addr: 0000E400 len: 0400
[12:59:10.934] kernel read area: addr: 0000E800 len: 0400
[12:59:11.164] kernel read area: addr: 0000EC00 len: 0400
[12:59:11.364] kernel read area: addr: 0000F000 len: 0400
[12:59:11.475] kernel read area: addr: 0000F400 len: 0400
[12:59:11.675] kernel read area: addr: 0000F800 len: 0400
[12:59:11.935] kernel read area: addr: 0000FC00 len: 0400
[12:59:12.156] kernel read area: addr: 00010000 len: 0400
[12:59:12.406] kernel read area: addr: 00010400 len: 0400
[12:59:12.576] kernel read area: addr: 00010800 len: 0400
[12:59:12.756] kernel read area: addr: 00010C00 len: 0400
[12:59:12.977] kernel read area: addr: 00011000 len: 0400
[12:59:13.197] kernel read area: addr: 00011400 len: 0400
[12:59:13.417] kernel read area: addr: 00011800 len: 0400
[12:59:13.628] kernel read area: addr: 00011C00 len: 0400
[12:59:13.948] kernel read area: addr: 00012000 len: 0400
[12:59:14.229] kernel read area: addr: 00012400 len: 0400
[12:59:14.569] kernel read area: addr: 00012800 len: 0400
[12:59:14.889] kernel read area: addr: 00012C00 len: 0400
[12:59:15.270] kernel read area: addr: 00013000 len: 0400
[12:59:15.580] kernel read area: addr: 00013400 len: 0400
[12:59:15.911] kernel read area: addr: 00013800 len: 0400
[12:59:16.261] kernel read area: addr: 00013C00 len: 0400
[12:59:16.582] kernel read area: addr: 00014000 len: 0400
[12:59:16.872] kernel read area: addr: 00014400 len: 0400
[12:59:17.223] kernel read area: addr: 00014800 len: 0400
[12:59:17.563] kernel read area: addr: 00014C00 len: 0400
[12:59:17.874] kernel read area: addr: 00015000 len: 0400
[12:59:18.214] kernel read area: addr: 00015400 len: 0400
[12:59:18.445] kernel read area: addr: 00015800 len: 0400
[12:59:18.705] kernel read area: addr: 00015C00 len: 0400
[12:59:18.935] kernel read area: addr: 00016000 len: 0400
[12:59:19.296] kernel read area: addr: 00016400 len: 0400
[12:59:19.596] kernel read area: addr: 00016800 len: 0400
[12:59:19.947] kernel read area: addr: 00016C00 len: 0400
[12:59:20.317] kernel read area: addr: 00017000 len: 0400
[12:59:20.628] kernel read area: addr: 00017400 len: 0400
[12:59:20.948] kernel read area: addr: 00017800 len: 0400
[12:59:23.011] ECU memory read failure.
[12:59:23.061] can't read image.
Old Jul 6, 2006 | 06:13 PM
ez's Avatar
ez
Nevermind...after several more attempts, it read out fine.
Kieran Fercher
12
Mar 24, 2020 09:37 AM
riraroli
Feb 8, 2017 09:25 AM
JohnnyTSi
Mar 17, 2016 04:53 PM
voltexct9a
Jan 22, 2016 05:23 PM
ball7068
Aug 31, 2012 07:48 AM
