Read from ECU window is blank...
Old Jul 6, 2006 | 07:47 AM
ez's Avatar
ez
Hey all... I posted this over on OpenECU.org but am not getting much feedback. It seems like I might be missing something simple...
Posted: Tue Jul 04, 2006 2:57 pm
"Hey everyone. I've been searching for several hours here and on EvoM and cannot find an answer to this.
2003 Evo 8
OpenPort 1.3 Mitsu form Tactrix
EcuFlash 1.28
Windows 2000 Pro
I can read OBDII data using EvoScan on the OpenPort, so I know at least that is working. Only EcuFlash is running, and I see OpenPort 1.3 listed in the bottom right as the interface.
When I click the Read from ECU icon, a small EcuFlash window pops up with two buttons, Read and Cancel. The white space in the window is blank, Read is grayed out, and nothing happens. Ignition on/off has no affect.
What am I doing wrong?
Thank you!
Ethan"
Old Jul 6, 2006 | 07:52 AM
chmodlf's Avatar
Make sure that you have under options at least developer level selected. This may or may not be your problem.
Old Jul 6, 2006 | 07:57 AM
ez's Avatar
ez
I was in advanced mode, and I think I tried developer as well. But I'll double check that...thanks.
Old Jul 6, 2006 | 08:07 AM
MalibuJack's Avatar
Try reinstalling it.. First, you need to make sure the driver is installed with the FTDxx.DLL driver, so the first thing you need to see is if that loaded, the other things in that window when you start the app is you need to see if it loads the mitsubishi related microcode.. If it doesnt, it means something is missing in your metadata, or your metadata directory is incorrect and it can't find the bootloader..
Copy and paste what the righthand pane says when you first start the app, make sure the cable is plugged in before you start the program, and that the OpenPort 1.3 cable port is selected..
Old Jul 6, 2006 | 08:19 AM
ez's Avatar
ez
Thanks Jack. As far as I could tell, everything loaded. I have the OpenPort selected, and it is listed in the bottom right corner. Here is the right pane output. How do I check to see if the driver DLL is loading? It's easy to tell that in EvoScan...
[00:51:08.512] Version 1.28.716
[00:51:08.682] 8 memory models read.
[00:51:11.256] 18 ROM metadata models read.
[00:51:11.256] checksum module "subarudbw" loaded.
[00:51:11.256] flashing tool "wrx02" loaded.
[00:51:11.256] flashing tool "wrx04" loaded.
[00:51:11.306] flashing tool "sti04" loaded.
[00:51:11.306] flashing tool "sti05" loaded.
[00:51:11.306] flashing tool "mitsukernel" loaded.
[00:51:11.306] flashing tool "mitsukernelocp" loaded.
[00:51:11.306] flashing tool "mitsubootloader" loaded.
Old Jul 6, 2006 | 08:20 AM
MalibuJack's Avatar
[18:03:27.062] Version 1.28.716
[18:03:27.062] 8 memory models read.
[18:03:27.359] 73 ROM metadata models read.
[18:03:27.359] checksum module "subarudbw" loaded.
[18:03:27.359] flashing tool "wrx02" loaded.
[18:03:27.359] flashing tool "wrx04" loaded.
[18:03:27.359] flashing tool "sti04" loaded.
[18:03:27.359] flashing tool "sti05" loaded.
[18:03:27.359] flashing tool "mitsukernel" loaded.
[18:03:27.359] flashing tool "mitsukernelocp" loaded.
[18:03:27.359] flashing tool "mitsubootloader" loaded.
This is from mine... Looks like your missing some definitions...
Old Jul 6, 2006 | 08:22 AM
MalibuJack's Avatar
If the cable wasn't loaded correctly, Evoscan wouldn't work, and you would get an error that says "Error Loading FTDxx.DLL"
Old Jul 6, 2006 | 08:27 AM
ez's Avatar
ez
Right...EvoScan works fine. So I still need to use the definitions you posted with the newest EcuFlash version?
Old Jul 6, 2006 | 08:35 AM
Mario's Avatar
Originally Posted by ez
2003 Evo 8
EcuFlash 1.28
Windows 2000 Pro
This maybe a noobie question, but will EcuFlash 1.28 run (or run properly) on Win 2000? I use Win XP as indicated on their website.
Mario
Old Jul 6, 2006 | 08:39 AM
ez's Avatar
ez
According to the forums on OpenEcu.org, yes.
Mario
Old Jul 6, 2006 | 11:07 AM
MalibuJack's Avatar
No, they are included with the newest version of ECUFlash.. not only that, but there are quite a few more than originally posted..
You need to verify the directory these files are in.. It seems like its looking in the wrong place for them or your missing the entire group of files.
Old Jul 6, 2006 | 11:34 AM
A418t81's Avatar
The program is pointed incorrectly as far as the metadata is concerned.
Go to option, rom metadata directory: It needs to read like this:
:/Program Files/OpenECU/EcuFlash/rommetadata (or wherever you have it installed, but my bet is that you have the program pointed further than just "rommetadata" and into the evo specific files which is too far....back out to just rommetadata).
Ask me how i know
Old Jul 6, 2006 | 12:10 PM
TTP Engineering's Avatar
Left field but make sure your port is selected correctly.
Old Jul 6, 2006 | 12:28 PM
ez's Avatar
ez
I did set the path to the files several times before I first posted. The Evo subfolder is selected.
When I get back home, I'll reinstall and reselect the directory/interface again.
I really appreciate the help on this everyone. I will start from scratch and let you know how it works. At least I know what the symptoms are indicating. Hopefully a simple wipe and reinstall will take care of it...
Cheers!
Ethan
Old Jul 6, 2006 | 02:01 PM
colby's Avatar
set the path to rommetadata only. that is your problem.
