My evo ix knock sum ok?
Old Jul 16, 2006 | 09:52 PM
  #61
RazorLab's Avatar
Originally Posted by P_Tune_C
The datalog was done in 3rd gear. Stock 05 turbo. this knock shows up only during night time for odd reason. on daytime it's fine. Also this is with 100 octane race gas.
You also might be boosting more at night landing you in load columns with lower timing.
Old Jul 17, 2006 | 07:45 AM
  #62
AlwaysinBoost's Avatar
Originally Posted by l2r99gst
nj1266,
I have seen you make this statement countless times. Just because you see an increase in ignition advance, it doesn't mean the ECU isn't pulling timing.
The ECU is still going to follow your timing profile based on your ignition maps and what RPM/load you are at. It's just that the the ECU will subtract timing from the value that it should be.
For a quick and completely arbitrary example, let's say that your timing should ramp up like this from peak torque:
3 5 8 10 14 18 (completely arbitrary just to prove a point)
Let's say that you get 6 counts of knock where the 14 and 18 were. Then your timing will look something like:
3 5 8 10 12 16
Of course the ECU will still advance timing. It will just apply the knock correction to it. I just keep seeing you say that you see the ECU ADD timing when there are knock counts. Sure....it is just following the timing maps and correcting as needed.
Eric
I found the exact same thing you said to be true. Even though your seeing knock the ECU will still advance the timing based on your map. You have to use a little creative logic to figure out which cell your actually in when this happens.
Old Jul 17, 2006 | 10:18 AM
  #63
Ludikraut's Avatar
Originally Posted by nj1266
+1 I have little faith in any electrical knock reading device. The more I read about knock, especially on the innovate forums, the more I believe that a well designed hearing aid with a head set will be the best way to go in detecting knock.
For fun, I have hooked up a wire from pin 78 on my ECU to my Innovate logging system. I will log the knock voltage and compare the changes to timing changes. My hypothesis is that increased voltage from the knock sensor pin will not overlap with pulled timing. We will see.
If you want to tap into the knock circuit, then you should do so using a knock buffer (like the Chip Torque knock buffer from Vishnu). IIRC, just hooking up a wire to log the signal can change the signal enough to impact the ECU's ability to determine knock.
l8r)
Old Jul 17, 2006 | 07:26 PM
  #64
nj1266's Avatar
l8r)
You are right. My experiment failed The voltage was all over the place. I guess I need to spring for the knock buffer
Old Jul 17, 2006 | 07:50 PM
  #65
DynoFlash's Avatar
That is odd as I log knock voltage in all my custom tuning - just as the AEM logs the knock voltage it is a 0 -5 volt signal
Old Jul 17, 2006 | 08:41 PM
  #66
nj1266's Avatar
hmmm...That is interesting. So you just tap a wire from pin 78 to the LMA-2 or the Aux box (LMA-3)? Did you re-set the LMA-2 by holding the rpm at 2k rpm and pressing the white button on the unit while the red light flashes?
The log I get is all over the place the voltage just spikes up and down with little to no meaning. The only time I can make sense of the voltage log is when I set the smoothing to max on that channel. Do you smooht the knock volt channel?
Maybe I am tapping into the wrong pin. What is the color of the wire that goes into pin 78?
Old Jul 17, 2006 | 08:56 PM
  #67
DynoFlash's Avatar
I use the LM3
Old Jul 18, 2006 | 01:01 AM
  #68
EFIxMR's Avatar
l8r)
Although I haven't tried tapping into the knock sensor, but I have tapped into various other sensors, water temp, mass airflow ect, and have found that tapping them changes the signal and causes the sensor to read improperly. This was done on my own car under a non load situation (idle) and immediately removed the taps.
However, I have seen other people's work (doing crazy things with the innovate aux box) and subsequently had to repair their wiring and all I have to say is proceed with caution.
Old Jul 18, 2006 | 01:25 AM
  #69
jcsbanks's Avatar
Input impedance appears to be 1MOhm on the LMA-3. Surely that wouldn't need any more buffering?
Old Jul 18, 2006 | 04:47 AM
  #70
On the EVO I've tapped the knock sensor wire using my innovative LMA-2 and was able to see voltage spikes that coinsided with timing being pulled as shown on my pocketlogger. This was a couple of years ago when I was using an AFC to tune. I've read some posts on the innovative forums about how you shouldn't interrupt the sensors signal so I stopped using that method. I did however work well for me.
Old Jul 19, 2006 | 10:27 AM
  #71
JeffR116's Avatar
I was tuned on 92 with 8 degrees of timing and was knocking like a motherf*cker with 94 octane. I had to pull 2 degrees to cut it down. It was ridiculous.
Old Jul 19, 2006 | 10:58 AM
  #72
EFIxMR's Avatar
Well there's always what works on paper and what works in real life.
Just know that on the particular car that I repaired the wiring had the injectors tapped for duty cycle...
When that car was running with the AUX box wired in that way, he ended up with cracked ringlands, and is now on its second engine. not sure if that is what caused it for a fact, but to me that is highly suspect.
Old Jul 19, 2006 | 11:33 AM
  #73
I'm actually not suprised by that at all. The difference in fuel quality as far as knock resistance goes is pretty amazing. Now that we actually have the ablity to monitor knock I'm finding out that all 93 octain fuel is NOT equal.
Old Jul 19, 2006 | 12:18 PM
  #74
EFIxMR's Avatar
If you are using EVO scan, to log knock I hear its best to take what the software says with a grain of salt.
  #75
ScrappyJack's Avatar
Couple of quick observations:
1. The AEM does have knock control that utilizes the factory knock sensor and can thus be every bit as good or bad as the factory knock control.
2. Because EvoScan says it is so, does not necessarily make it so.
3. I have also been advised against tapping directly into the knock sensor wiring for logging voltage without a buffer. The AEM isn't tapping into the wiring - it's taking the signal directly from the knock sensor via the factory wiring harness. Hopefully someone with a little better understanding of the magic of electricity can expand on that.
