My evo ix knock sum ok?
Old Jul 19, 2006 | 09:50 PM
  #121
mchuang's Avatar
Originally Posted by DynoFlash
I really cant stand it when someone who I would consider a flash newbie starts to draw conclusions and makes inccorect statments of opinion and casts them as firm FACTS.
I am really not interested in debating these matters with you as I feel it would only serve to further enhance your now limited understanding of how eaxctly the stock ecu works.
I have been tuning evos on a daily basis since the first evo was delivered here on the east coast now over 4 years. Thus far there have been ZERO reported tuning related engine failures out of the hundreds and hundreds and hundreds of customers I have tuned one way or the other. Some of my customers have gone over 100,000 miles on my tunes and have particpiated in every form of sanctioned racing.
Oddly, the customers I have tuned are consistanly the fastest out of any reflash tuned evos in the US and enjoy reliability and durability as good or better than any other tuner - or stock for that matter.
I am not here to detract any other tuner but to rather let my work speak for itself.
I find it very regratable when other tuners try and advance their notariety by attacking my work.
It is even more bizzare when the assertions being conveyed are 100% incorrect.
What the hell does this have to do with what you quoted from him. It is like you have this saved somewhere and you copy and paste it all the time. He just said what does the stock ecu do when low/hi maps are the same.
Old Jul 19, 2006 | 09:55 PM
  #122
mchuang's Avatar
Originally Posted by EFIxMR
I don't know anything about the DSM ECU so I cannot comment on that, but my hours of dyno testing on the EVO ECU shows no timing pull when the High/LOW octane maps are the same.
This is evidenced by the torque curve remaining in the same pattern on the dyno.
I think what he is trying to say here is that if there is knock with hi/low oct maps the same and the ecu detected it it would pull timing and of course if it pulled timing the torque curve would drop.
Old Jul 19, 2006 | 11:24 PM
  #123
nj1266's Avatar
rpm----ks---tim
4343---0----8
4500---2----7
4750---2----8
4937---1----8
5125---1----9
5312---1----9
5500---1----9
5687---0----11
5875---0----11
Could you please tell me what are the timing values that are in your timing map at the above rpm and load levels? How far off are the above numbers from your timing map?
Originally Posted by 5k6
I did some more logs with different fuels:
Mobil:
Phillips 66:
Old Jul 20, 2006 | 12:48 AM
  #124
RazorLab's Avatar
Thank you for the response Eric.
Old Jul 20, 2006 | 11:28 AM
  #125
EFIxMR's Avatar
Originally Posted by l2r99gst
Making the low and high octane maps will not override the knock sensor.
To answer the question that razorlab has posted a few times:
1. Yes, the stock ECU will still pull timing if the low/high octane fuel and ignition maps are the same
2. What causes the high/low octane maps to be used? I can only speak for the DSM ECU...perhaps Al can tell us his experience with the Evo ECU.
But, the ECU store a calculated number called the octane number. This number changes due to certain conditions, such as knock, over a period of time. The lower the number, causing the ECU to use the low octane maps.
DSMLink reset this octane number everytime that you started your car, so that you knew that you were always in the high octane maps.
Since I haven't studied the Evo ECU enough, I can't tell you the exact conditions or length of time under those conditions where the low octane maps are used. But they are they basically for the reason of how they are named....if you get a bad tank of gas, lower octane gas, or are just under extreme conditions where your car is more prone to knock (high coolant temps, intake temps, etc) then the octane value in the ECU will be lowered and you will use the low octane maps.
I doubt Al or anyone that knows exactly how this works will simply give the information out freely, but that is basically how it works.
Eric
I apologize if i've come off the wrong way to you Eric, as this post above is extremely informative about the DSM ecu.
However, my independant testing with the EVO ECU shows different.
Mchuang got it exactly correct.
When you make the low det and high det maps the same provided that the fuel and timing maps are done correctly it will make the engine produce an extremely clean dynograph. Provided that you put in just the right amount of timing in the correct places it will expose an engines optimal Maximum Brake Torque curve for that given fuel.
Maximum Brake Torque Timing is defined as
Originally Posted by Mechanical Engineering 435: Applied Combustion
If start of combustion is too early work is done against piston and if too late then peak pressure is reduced. The optimum spark timing that gives the maximum brake torque, called MBT timing occurs when these two opposite factors cancel. Engine at WOT held at a constant speed and afr.
If you were to change the low det map back to stock, the above optimal curve will be changed certainly, maybe not in all spots but there will be dips. Those dips are where the ECU believes there are knock.
Change the low det map identical to your high det map, and immediately those dips will be patched. The percieved knock is still detected by the ECU but it has been overriden.
This is fact.
While making the maps identical draws a perfect dyno graph, it affords no knock protection IMHO, which is gathered from my testing.
Leaving an engine on MBT timing on pump fuel should never be done unless...
1. It is your own car, and can man up to the consequences for running a hot tune.
2. You're customer specifically request it, and you have informed him of the consequences. (You'd be surprised how many people actually want this)
However that is not to say leaving the low det and high det maps identical are necessarily wrong or dangerous. If you detune the engine by retarding the timing a decrease in 5% - 10% in torque it affords a good safety margin.
This is how it is done tuning stand alone ECU's all the time without failure given a competant tuner.
In many ways this is a hack, and the guys who criticise this technique are justified because to tune with twin maps is substantially more time consuming and comprehensive.
Twin maps will afford an even greater safety margin, and if done correctly will not produce large dips in torque.
Still in some areas, parts of the map can be made indentical if your experience tells you the ECU is picking up phantom knock. These areas are found through sound judgement, and extensive testing on your own vehicle and not customers.
I consider the techniques above only to be tried by experienced users, follow at your own risk.
Thanks!
Old Jul 20, 2006 | 11:44 AM
  #126
jcsbanks's Avatar
So are we saying that we think the ECU interpolates between the high and low octane maps depending on knock count?
Old Jul 20, 2006 | 11:51 AM
  #127
EFIxMR's Avatar
That is a definate possibility
Old Jul 20, 2006 | 12:04 PM
  #128
l2r99gst's Avatar
EFIxMR,
No hard feelings. We're just both relaying our experiences. We're all here to teach each other.
Perhpas more people can validate this when we get better logging abilities and dyno time, as will I soon. I have barely had any time to mess with the Evo Ecu as much as I would have liked, but I find it very strange that you would see no timing retard when you made the maps the same.
Knock correction uses different tables and calculations than just the low/high octane fuel/ignition tables. However, your experiences tend to show otherwise. Since most of my experience is with the DSM ECU, I'm not sure what is truly correct at this point.
At first when you posted about your torque curve, I didn't reply because you could have had timing being pulled throughout the run, which would still produce a clean looking torque curve, as long as the knock was consistent and roughly the same amount through the pull. But since you said that with the same exact conditions back to back making the low/high maps the same didn't produce knock and putting the low map back to stock did, that is extrememly interesting to me.
I will still take it with a grain of salt, though, until I can substantiate the claim. But I definitely appreciate the good data. Sorry to get off on the wrong foot earlier.
And I do agree with your tuning methods concerning MBT and pump gas. Without getting to technical, that is basically what I was trying to say about getting a safe, knock free tune. Obviously, you want as close to MBT as possible, but depending on your AFR and boost you may be nowhere close to that. And some people like to tune for low boost, high timing (close to MBT) and some like high boost, low timing, and don't even care about approaching MBT.
But regardless or the tuning method, the most important factor that I use is knock, as recorded by the stock ECU. I always tune up to the point where knock would begin to occur and then back it off in one of three ways, either fuel, timing, or boost.
Thanks for all your info,
Eric
Old Jul 20, 2006 | 12:57 PM
  #129
EFIxMR's Avatar
Eric,
Please keep us informed on what you find with the EVO ECU, so we can truly figure out what's going on. I'll be heading out to the dyno today to tune a friends car, and ill will try to duplicate what I was describing earlier. I will document the process, and print out the actual graphs of the change between tuned identical maps and a tuned high octane map with a stock low octane map.
Old Jul 20, 2006 | 03:12 PM
  #130
AutoXer's Avatar
I wonder if ECUFlash could pull that number from the ECU? BTW, there are unknown parameters that it can pull. EVO4MAD gave the option to poll the values in the latest ECUFlash version. We've just got to figure them out. Has anyone messed around with them yet?
Old Jul 20, 2006 | 05:20 PM
  #131
DynoFlash's Avatar
Eric,
Yes, please do "truely figure out what is going on" - FIRST
And then, afterwards post on the internet lyour conclusions about HOW it works
This is more helpful than stating what you assume first and then finding out what is going on later. This is especially the case when what you are asserting is not correct.
Just my two cents
PS - Just for reference, the ideal way to tune an evo is so that there is a total absense of knock activity what so ever -and a significant margin of saftey below the knock threshold. Of course on 91 octane vehicles and with the new summer gas that some areas are getting this can be a very tedious process. Knock can be RESPONDED TO by the ecu in a very quick manner however it does create physical stress upon mechanical parts when it occurs no matter how briefly and it also will result in an unsmooth feeling as the stock ecu pulls the timing only in small areas of the map. I prefer to set up my tuining so that the cars run totally under the knock threshold.
No matter WHAT you set the so called high and low octane maps to - if the ecu picks up what it calculates as knock activity it can and will immediately PULL as much timing as needed to remove the knock. I have seen some evos with engine noise problems go up to - 9 degrees of timing advance all the way through the power band with both ignition maps set the same.
Again, the only way to test or confirm this theroy is to fix both maps the same and then either lean out the car or raise the boost enough to cause detonation. IF you log your timing you will see that the ecu is pulling timing in direct relationship to the knock count - IRRESPECTIVE of what the relationship between the high and low octane maps is.
Of course all of this gets more dicey in a IX evo which has 6 - 7 ignition maps depending on which ecu version is used.
Finally - there is nothing wrong with setting the multiple ignition maps up with different levels of timing and many of my maps are set up in that manner.
However, in certain situations it is very advantagous to fix the maps the same for reasons which I do not care to discuss.
My main point is to disagree with the claimed assertion that the ecu can not pull timing if the maps are fixed the same - this is totally false.
Old Jul 20, 2006 | 05:34 PM
  #132
stingerbtry's Avatar
I wish my e-flash agreed.
Old Jul 20, 2006 | 05:41 PM
  #133
taenaive's Avatar
This is very true. I actually saw this happening numerous times with evoscan logs on my car. Not only timing.... fuel also get super rich.
Old Jul 20, 2006 | 06:10 PM
  #134
DynoFlash's Avatar
E FLASH! is a base flash which is geared towards do it yourself tuners so that they can have a close base starting point which matches their combination of modifications
Many customers actually use it as their final map and just install it and drive and the E FLASH! will generally work very well for this kind of application
However - E FLASH! is not a replacement for a full custom tune which takes me 2 hours of testing and adjustment to complete
Particularly on 91 octane california fuel getting the car to achieve maximum power, avoid knock induced timing retard and have a great "feel" takes a lot of time and careful balancing. 91 octane fuel in particular is a tough challenge.
My concept in creating the E FLASH! maps was to make it easier for do it yourself tuners to have a good starting point and a safe starting point. It is not a replacement for fine tuning as indicated.
Old Jul 21, 2006 | 04:55 AM
  #135
dudical26's Avatar
Correct me if I am wrong, but an E-flash is the same thing as the mail in flash except the customer actually applies the flash to the ECU.
