quick question
Old Jul 20, 2006 | 03:55 PM
leggomycraigo's Avatar
quick question
i got an eflash from al for my stock ix...finally got my boost gauge and forge mbc so i got the gauge in and i noticed im hitting 15psi max...havent hooked up the mbc yet...ill do it over the weekend. but curious as to what you guys think.
Old Jul 20, 2006 | 06:26 PM
TTP Engineering's Avatar
I think you should get it at least to stock boost level.
Old Jul 20, 2006 | 06:30 PM
Mad_SB's Avatar
does the car feel weaker after installing the gauge or did you do it all at once? You may have introduced a leak when you installed the gauge.
Old Jul 20, 2006 | 06:55 PM
stingerbtry's Avatar
My boost psi was not an issue with Al's flash. It boosted to ~20psi and held there. Sounds like mad_vIII may be right and you may have introduced a leak when installing either your boost guage or mbc. Either that or the mbc may need to be tweaked. Mine held boost great and I have a completely stock IX MR with just the stock guages.
Old Jul 21, 2006 | 05:01 AM
i cut one line so far for the gauge, no mbc installed yet...i find it highly unlikely a new leak was formed, zip tied all the connections on the t and the gauge...it seems to be pulling like before...
Old Jul 21, 2006 | 06:14 AM
MalibuJack's Avatar
What line did you cut for the gage? If you cut the line to the DV and put a T in.. you might have introduced a restriction preventing it from firmly staying closed.
Old Jul 21, 2006 | 06:24 AM
https://www.evolutionm.net/forums/sh...ad.php?t=98114
this is the thread i used to figure out where to tap it at
