Logged the 2 step today
Old Aug 3, 2006 | 11:16 AM
dudical26's Avatar
Originally Posted by dan l
If you pull back some timing on the launch box you can get more boost. I can get it to spike to 20psi on a 50 trim at 6000 or 15psi at 5500.
P.S.
I'm going to try to see if John Bradley can get the code to work in his evo then I'll make a writeup once its all figured out.
Mind posting the relavent sections of the timing map?
Old Aug 3, 2006 | 02:47 PM
dan l's Avatar
I’ll let you guys run with this, there are some smart people here who can figure it out. This is some code that Kyle wrote and I helped test. I made an edit to it so that it watches the VSS before going to NLTS as is desperately needed. I *think* the evo ecu still uses the HC11 processor and as such the opcodes should still work. Might want to double check that you canuse accumulator A. Also The addresses on the side mean nothing, but that is where they are in a DSM ecu. You’ll have to either find an input or see if the stock clutch switch is an input to the ecu. I know MR’s have a clutch switch on the top so may be able to use that or wire one in their on non MR car’s. So just change the addresses in the code so that the locations match that to the evo ecu. Once somebody can get this code working we’ll work on pulling back ignition timing any time the clutch is in.
96 C6 LCAA L00C6 ; load speed sensor into accum. A
81 75 CMPA $0075 ; test if car is moving
23 04 BLS ; if car is moving skip next 4
8C 03A9 CPX $03A9 ; car is stopped launch stutter
39 RTS ; return from subroutine
81 10 CMPA $0010 ; compare VSS with 10h
24 06 BHS ; slower than ~30mph skip next 6
96 06 LDAA L0006 ; load clutch bit into accum. A
85 20 BITA $0020 ; accumulate with 0020h
27 04 BEQ ; if clutch is in go to NLTS
8C 01F4 CPX $01F4 ; clutch is up stock rev limiter
8C 02AA CPX $02AA ; NLTS stutter RPM
39 RTS ; return from subroutinee
Old Aug 3, 2006 | 03:00 PM
jcsbanks's Avatar
Evo is SH2.
Old Aug 3, 2006 | 05:09 PM
l2r99gst's Avatar
The stock clutch switch (the top one that needs to be used here) is an input into the Evo ECU already.
It wasn't on the DSM and we had to wire it into the ECU for NLTS with DSMLink.
Eric
Old Aug 3, 2006 | 06:15 PM
JohnBradley's Avatar
I havent got a chance to start on this. From what I gathered from your PM Dan, I need to find these locations in the .bin and see if a) they are the same as you have coded or b) figure out the new code and implement the rest of the subroutine, yes?
Old Aug 3, 2006 | 10:34 PM
ST's Avatar
ST
very interested in ya'lls findings on this...great work so far!
Old Aug 3, 2006 | 11:29 PM
andenbre's Avatar
completly out of the blue here but I had my 2 step set to 3800 approx and all day to day it wasnt working. rev at a stop clutch in andit would hit 7 grand. maybe its too low I will change it and let ya know what I find
Old Aug 3, 2006 | 11:31 PM
Interesting. I have had intermittent problems with the LC when I had it set at 6K once. The first time I flashed the ECU, the LC went away completely. Then I reflashed and it was back.
Old Aug 4, 2006 | 05:53 AM
dan l's Avatar
Originally Posted by jcsbanks
Evo is SH2.
Any links to the opcodes so that new code can be written?
Old Aug 4, 2006 | 06:55 PM
I hate to post just to say this, but wow this is exciting.
Old Aug 11, 2006 | 09:21 AM
fixem2's Avatar
Any update with this? Like to be able to build a we bit more boost at the track this weekend.
Old Aug 11, 2006 | 10:17 AM
dan l's Avatar
The 2 step in ecuflash can build 10psi easilly in a stock car. It should be sufficient for most people. I still can't find the opcodes for the evo ecu. Also if anybody knows of a nice 04 or 05 evo for sale in the northeast I need to buy my own so that I can do testing.
Old Aug 11, 2006 | 11:43 AM
honki24's Avatar
just on a side note for those who are concerned about their clutch: I've lowered my launch to 3500, now waaaiit... waaaiitt... don't bash me, lol, and it builds about4-5psi on its own, but if you slip the clutch right, you get the same 10-12psi outta it before you launch. My clutch is being replaced next weekend so I was able to test this out.
Note:May be prudent to test this out before going to the strip w/ it, not very easy to get the slip down w/o moving, but definatley doable. However, for those of you who actually do go to the strip... the 5800 or so RPM launch is probably just easier and more effective for you. I just needed something to keep my foot outta doing it b/c it was too much fun and I dont wanna destroy my next clutch.
Old Aug 11, 2006 | 11:56 AM
anyone that is looking into this that hasnt also removed the factory POS clutch restrictor will also want to do that before mad boost launch at high rpm and therefore save clutch (as much as high rpm high boost launches will)
Old Aug 11, 2006 | 12:22 PM
fixem2's Avatar
John, I was under the impression that the restrictor was helping to save the clutch. I am still on the stock clutch and haven't replaced the line.
