Question, ECU load determining accuracy
Originally Posted by speed kills
Thanks Man, Are they going to be posted any time soon or in couple of days.
Originally Posted by ST
lol...no probs...beers still on me if you're ever down here.
jcsbank - i will try to redo the file order as well as increase the baud rate and see if this helps.
https://www.evolutionm.net/forums/sh...d.php?t=214146
and looking at his maps where he has quite a bit of entries for a small 100% wot pull from 4k - redline, it seems i have some issues with the i/o stream from my ecu to evoscan. the log i posted was supposed to have at least 3-4 wot pulls from 2nd, 3rd, and 4th gears, but after further review, it seems there is only a few short entries for 100% tps pulls. =/
what baud rate and laptops are you all using?
time to debug... =(
Originally Posted by razorlab
I was noticing that in your log too ST, it's worse then a pocketlogger at default settings. hah.
How many things are you trying to log at once?
i'm trying to log every available stat i can...you can never have too much info imho =)
i think i've resolved the problems now after tweaking to jcs's settings. initial results seem much better, but i'm still getting very high load cells in the 280-290 arena w/ the afrmap lookup, which to my understand, hardly ever occurs unless highly modified?
Okay guys, the long awaited updated definition files..
I updated the data.xml I placed the AFRMAP and Injector pulse data items right next to eachother so your sample is accurate... I also added speed in MPH (let me know if it works)
I also updated the EvoScan.txt file, this is used for the universal data log importer tool in data log lab...
Eventually my Evoscan log analyzer will do most of this for you, but the next release will calculate load site so you can graph it in data log lab..
See later post.. This file had a big typo in it causing an error that I didn't catch (My car is home and I'm at work)
www.dataloglab.com (do a search in this subforum for my thread about it) its by far one of the best tools I've worked with.. Basically it graphically displays relationship of data..
I tried that xml file, All I did was copy and paste it into the folder started evoscan it started to initialize then I got an error. Put my regular one back in and it works fine. Here is a screenshot attached
Ok I got it to work now, I copied and pasted the load portion of your xml file into the regular data xml and it works, but at idle it says 110% - 127%, which is odd if you guys say that boost is after 100%
