Question, ECU load determining accuracy
Old Aug 24, 2006 | 01:47 PM
  #106
A418t81's Avatar
Wait, I thought that the "load" value thats added with this XML WAS the calculated value and that AFRMAP was the decimal value. Do we still need to plug into Excel?
Old Aug 24, 2006 | 02:15 PM
  #107
jcsbanks's Avatar
The "load" value that was in the xml was actually what I'd found previously, but it turned out it was my JDM/UK IX 3 bar map sensor! Gives a very close reading to load which is why it puzzled me!
The new load estimate as detailed in this thread cannot be done in the xml file as it cross references two data items. So Excel it is, and once verified or improved/replaced, MalibuJack may put it in his log reader I guess.
Old Aug 24, 2006 | 03:10 PM
  #108
Ludikraut's Avatar
-= HINT =-
If you're tired of checking/unchecking various boxes in Evoscan everytime you startup, open up the DATA.XML file using Notepad, then find the lines that are for parameters that you normally don't log and change DataLog="Y" to DataLog="N" for those parameters.
l8r)
Old Aug 24, 2006 | 04:51 PM
  #109
MalibuJack's Avatar
That load value is from an earlier thread.. It turned out that was the Map sensor.. Load would still have to be calculated using Excel, but when I release the new version of my log analyzer (the one that converts the files to work with data log lab) it will do the calculation for you, then it will be in the output file so you can look at it with something usable like Data log lab, or Excel..
Old Aug 24, 2006 | 05:08 PM
  #110
speed kills's Avatar
MalibuJack, Thanks for the files.
Old Aug 24, 2006 | 05:48 PM
  #111
andenbre's Avatar
thanks again Jack
Old Aug 24, 2006 | 06:25 PM
  #112
nj1266's Avatar
Originally Posted by Ludikraut
-= HINT =-
l8r)
Ludi,
Thanks so very much for this. I was getting so annoyed having to check and uncheck the boxes.
Old Aug 25, 2006 | 09:48 AM
  #113
ST's Avatar
ST
No it can occurr of the boost spikes at lower RPM..
Seems I am still getting calculated AFRMAP load cell values of 300-312 or so at WOT (see attached). With 852 calculations, it seems to max out at 300, which seems more inline.
note: this is with ~21-22psi of boost.
Old Aug 25, 2006 | 10:59 AM
  #114
Ludikraut's Avatar
In order for the new formulas to give me load values that seem to be in the correct ballpark, I have to:
a.) adjust the constant to 3100 in Excel if using calculated load = abs(3100 * (IPW-0.4) / AFRMAP)
b.) adjust the constant to 3000 in Excel if using calculated load = abs(3000 * IPW / AFRMAP)
l8r)
Old Aug 25, 2006 | 11:17 AM
  #115
nj1266's Avatar
The new Data.xml file that Malibu posted is not working for me. I removed the original file and added the one from malibu, but everytime I run Evoscan with it I get and error message and the logging session starts and ends with no data logged. When I switch back to the original Data.xml file Evoscan works like before. I have no idea what is going on. Any help?
Old Aug 25, 2006 | 11:26 AM
  #116
Ludikraut's Avatar
Don't log the vehicle speed. There is still an error in the XML file. I'll post a fixed file shortly.
l8r)
Old Aug 25, 2006 | 11:27 AM
  #117
Ludikraut's Avatar
I've been looking at my latest set of logs, and the IPW based load calculations are nowhere near accurate enough, IMO. Even with adjusting the "constant", it still tends to be +/- 20% from the actual load on my car.
l8r)
Old Aug 25, 2006 | 11:55 AM
  #118
Z_Lancer_Man's Avatar
Do these load calculations work for other Lancers as well? Or is this general to all Mitsu ECUs, just Lancers (EVO, Ralliart, Lancer) or just the EVO? Anyone know?
Old Aug 25, 2006 | 11:59 AM
  #119
nj1266's Avatar
l8r)
Well get going and fix it (just kidding).
Old Aug 25, 2006 | 12:16 PM
  #120
MalibuJack's Avatar
There was an error in the first file.. Check the other thread for a slightly later post with a newer file.. Hopefully that fixes it.. The files work fine on my setup.
