SuperH emulator
Old Aug 31, 2006 | 03:20 PM
jcsbanks's Avatar
SuperH emulator
http://www.lauterbach.com/cgi-bin/do...file=simsh.zip
Just found the above emulator.
When you load up TRACE32, close the windows it comes up with and go to the file menu then "Load" your .hex file. Don't change the CPU type from SH7040 even though it doesn't match. Then View...list source. View...registers.
Reset the PC to 0 and track the first vector.
You can also view...dump from address 0 and then scroll down to the RAM area and it does update appropriately. Peripherals don't seem to emulate, and we don't know the channels they're on either.
Old Sep 1, 2006 | 05:05 AM
jcsbanks's Avatar
If you download the http://www.lauterbach.com/cgi-bin/do...ile=monsh7.zip monitor program, then the .per files in there can be put in the directory where you installed TRACE32 and then you can see the peripherals.
Old Sep 1, 2006 | 05:50 AM
jcsbanks's Avatar
You can change the CPU type to 7055 as well if you change the direction back to up in the same window. Then close the demo windows and "load" you hex. Then view the peripherals, list the source, see the registers, stack etc. Looks nice.
Old Sep 1, 2006 | 06:51 AM
MalibuJack's Avatar
Nice.. I'll take a closer look at that..
Old Sep 1, 2006 | 07:11 AM
MalibuJack's Avatar
This looks really promising.. Considering you can create a comments file for it, maybe we can use this for exchanging data on the rom?
I'm fighting the app right now, its alot to absorb in one shot.. LOL
Old Sep 1, 2006 | 07:35 AM
jcsbanks's Avatar
It took a lot of googling to find emulators/simulators for various microcontrollers.
I wondered about doing some resistance checks between known ECU pins and pins on the microcontroller, although they are tiny surface mount pins and my multimeter probe is a little phat I don't think this would harm it, and we should be able to identify the channels and get labelling better.
Old Sep 1, 2006 | 07:39 AM
MalibuJack's Avatar
Hey if you have the patience, then go for it.. I have an extra 03/04 ECU that I probably can look at if I ever have the time.. But I did notice that the ECU board had a JTAG pad of some sort..
Old Sep 1, 2006 | 07:53 AM
jcsbanks's Avatar
Can you get a photo of the bit you mean?
Old Sep 1, 2006 | 07:56 AM
MalibuJack's Avatar
Yeah when I get out to the shop I'll snap a photo of it..
Old Sep 4, 2006 | 10:44 AM
silver_evo's Avatar
Wow, now comes the reprogramming of the ecu , if you can view the code , then you are effectively disassembling the program. I hate messing with assembly though, you cant change things like you can in C or another language, its yucky. Stupid addressing.
Old Sep 4, 2006 | 10:49 AM
jcsbanks's Avatar
I still wonder about rewriting the ECU from scratch. It would probably be easier, except I have no experience/detailed understanding of code to control MIVEC.
The basics to run an engine are not so bad at all, it is getting it into a nice overall package that takes work.
I've already done previous work to make 3d maps chuck out voltages or duty cycles based on RPM and MAP.
The complex stuff is fault checking, OBD, stuff like that.
Old Sep 4, 2006 | 11:22 AM
silver_evo's Avatar
yeah that would be no easy task. Injector timing, ignition timing, all from scratch?! I had toyed with the idea of a SuperH based ecu which is funny that the actual ecu uses SuperH, but i had probems with software driven pwm for fan/wg solenoid control. Im not sure how the stock ecu handles duty cycle (its probably hardware driven by a register/buffer) and the ecu just sets the value, i didnt have the knowledge to do hardware duty cycle, maybe with a 555 but id need one for each solenoid... ugly.
Old Sep 4, 2006 | 11:36 AM
jcsbanks's Avatar
I've done Atmel AVR stuff so the hardware stuff is actually quite intuitive. We're not dealing with a terrible number of signals.
PWM stuff - generally you just set a mode register and then set a compare match signal. The chip double buffers it all for you. Starting PWM is as easy as printing to a display on a microcontroller with integrated hardware.
Old Sep 4, 2006 | 12:17 PM
colby's Avatar
An emulator is a handy additional tool if you are having trouble understanding what a sequence of instructions does, but in general I prefer to use a disassembler to gain the most understanding of how things work. Unfortunately, that is a tedious process. The problem with emulation is that you must build an accurate model on all of the sensors and actuators (I/O) for the emulation to run in a meaningful way. Even if the emulation runs perfectly, it doesn't always give you insight as to how the system actually works. It's a useful tool to have, I just wouldn't suggest that you look at it as your primary tool.
Old Sep 4, 2006 | 12:28 PM
jcsbanks's Avatar
I'm using IDA Pro mainly, trying to decode the serial routines (particular the ones that Evoscan requestIDs get processed by to make their reply) to chuck out the load and then redefine the pointers to the fuel and timing maps to RAM.
Colby, are you willing to share any info on the actuator and sensor channels, and the serial routines?
