For those who can get a decent load calculation
Old Sep 5, 2006 | 06:23 AM
jcsbanks's Avatar
I know speed density isn't fashionable, but with the correct enrichment it is smoother on/off the throttle than a MAF based ECU with a FMIC and dump valve I find.
It would be so tempting to change the ECU code to substitute the 3 bar MAP sensor (original on IX JDM or retrofit) value for load at some point, with an inlet manifold temperature correction, I think the sensor is there as well on my IX.
Old Sep 5, 2006 | 08:07 AM
nj1266's Avatar
Could someone please type in the formulas they are using for load. IIRC, there were 3 of them, one of them is the is the airflow/rpm*852. What about the others?
Old Sep 5, 2006 | 10:00 AM
C6C6CH3vo's Avatar
Think your load calc is off, something is off here:
RPM InjPuls TPS AirFlow Battery load
4188 18.944 100 1245.42 13.4872 559
4438 18.688 100 1314.61 13.4872 544
4594 18.688 100 1339.77 13.4872 538
4719 18.176 100 1383.81 13.4872 517
4906 17.9200 100 1446.71 13.4872 504
5063 17.9200 100 1503.31 13.4872 498
5219 17.9200 100 1541.05 13.3406 493
5406 17.15200 100 1566.21 13.4139 466
This is at peak, 5500RPM up is 1603 hz
As long as ECU isn't reading that
Old Sep 5, 2006 | 11:53 AM
MalibuJack's Avatar
I dont see ANY COLUMN for AFRMAP.... Its not going to work unless your logging the afrmap value also...
Old Sep 5, 2006 | 11:56 AM
MalibuJack's Avatar
The header names also matter... thats why I supplied a Data.xml file.. Your just not logging the correct information..
Old Sep 5, 2006 | 02:13 PM
C6C6CH3vo's Avatar
Oh, the Data.xml has the stuff I need - I was trying to use the conventional 0.8 to get load no wonder my load way wayy off. I'll see if I can get it up and running tomarrow
So this is what I need to do, right?
  1. Somehow load the data.xml to my evoscan
  2. do some logs with the add collumns like afrmap (and others)
  3. Drag and drop my new logs into my calculator
Thanks MalibuJack
Old Sep 5, 2006 | 02:29 PM
mchuang's Avatar
Thanks MalibuJack
yea just copy and paste the xml file to evoscan, make a run log it in evo scan. When finished open up the drag and drop program..drop your excel log in it where it says drag here...now there is a notepad file also that you can use with datalog lab to help you view your log in graph format..
Old Sep 5, 2006 | 06:11 PM
C6C6CH3vo's Avatar
Cool, thanks dudes, this gave me MDP, speed, and AFRMAP - ended up being just like the OCT addition 2 weeks ago, can't believe I missed this one too.
Thanks for the neet stuff and hard work,
I dont need to do anything with the EvoScan.txt file do I
Old Sep 5, 2006 | 06:17 PM
mchuang's Avatar
No unless you are going to use datalog lab which is awesome
Old Sep 6, 2006 | 04:51 AM
honki24's Avatar
so has anyone seen the OCT number go down? My GM MAS is going bad I fear and I had terrible knock and misfire up top yesterday while doing pulls. I showed in excess of 3 volts for knock and evoscan said up to 4 counts in a few places, but OCT stayed 255 solid. (I do have my maps flat for tuning purposes right now, but that shouldn't affect the logic correct?)
Old Sep 6, 2006 | 05:28 AM
justchil's Avatar
Generally 285-315 depending on the gear. Normally right at/under 300.. only time I've seen it go over is while spinning in 2nd gear. Running 24-26psi.
Old Sep 6, 2006 | 08:35 AM
C6C6CH3vo's Avatar
Just chil, what % MeOH/H2O are you at now?
OT: I'm about to do a clutch install, would you recommend your old 2004 write up, or Evomoto's for the procedure? Good 1/8 mi runs BTW
Finally got the right load and correct info, thanks for the help yesterday MalibuJack and Mchuang!
Man this stuff gets more fun and useful by the day!
EDIT - WOW, thats small,
Old Sep 6, 2006 | 10:03 AM
justchil's Avatar
Never seen MeOH lol.. is that alky? I'm running around 50/50. Sometimes I put a lil extra alky in just for kicks.
I got some new logs today... once I've review them I'll post them up (if anyone wants to see them).
Old Sep 6, 2006 | 11:55 AM
mchuang's Avatar
Mine hasn't went down and my maps are not the same at all.
Old Sep 6, 2006 | 12:13 PM
jcsbanks's Avatar
Octane decrements if knock sum >=6
