Knock sum=36, octane number=0, forged pistons, false knock story
This is what the owner just PM'd me:
"I have been out in the car with the det cans. I carnt hear any loud clicks etc but i can hear what i think is a lot of tappet noise its constant and can be heard at tick over and gets more intense the higher the revs get, and i must admit they are quite noisey do you think this would be picked up by the sensor?
I have also done a compression check and that is ok, Also the car ticks over nice and smooth "
Some say it could be the tappets and have seen this, some say they think it unlikely.
HOWEVER, I think this may call for a controversial KNOCK FILTER tweaking thread if anyone is so brave as to venture into that territory. Would be interesting to see nonetheless if this phantom knock could be "tuned out" using the knock filter in that specific rpm range.
The downside to that is that it appears in a location which is also known for peak torque, an area you WOULD want the proper protection from REAL knock.
Originally Posted by TTP Engineering
With 16 years of lifter tap, I am sure that the Mitsu Engineers would not have an issue like this.
Logging my '90 and logging a IX Evo it is pianfully apparent how the code seems to be nearly identical. The Evo's WILL pick up Lash Adjuster tick just like a DSM. Heck, the register location in the ecu is the exact same from a 1990 DSM to a IX ecu for the knock sum.
Even in my 99 ECU, I would get phantom knock from lifter tick. Luckily DSMLink had a feature that let you ignore the knock sensor based on certain variables, such as TPS, RPM, etc.
But yes, I did get a lot of phantom knock just from noisy lifters. My GST had 117K I believe and the phantom knock started around 100K or so from the lifters. Used DSMLink to ignore knock sensor for low throttle/load in early RPM range and all was well.
Eric
Jack and John, you reading this? Its a wonder why this wouldn't be a feature from the factory. What boosted car knocks under 100kpa?
If your rods are knocking you have a bigger problem.
We definately need a way to differentiate off load noise. This is a ridiculous problem to have with such advanced technology.
Actually in the DSM code the ecu would ignore knock, however it was at a super low level. It was so low that it only really ignored knock when the car was idling. This was probably only done to keep the car from yanking 20 degrees of timing and stalling the car.
John posted his EUDM IX rom's disassembly in progress on aktivematrix if anyone wants to look at it and see if any of the data looks familiar. John did notice that quite a bit of the items are similarly located (if not the same) for many of the roms 8's and 9s included.
Sorry TTP, time zone differences make it difficult to reply promptly.
The knock control seems to be disabled until you are almost out of vacuum from this log 0,0,0,0,11,36,36,36, for example.
I've not found knock filter stuff like the US models in the UK/JDM ROMs. I had a brief look. Trouble is with 12 or so tables in some of the models, which to adjust. The knock control code is convoluted in the extreme.
If we get custom comms going I might be able to setup a way of telling which maps are being accessed.
I had imagined that the filtering was analogue (excuse my quaint English spelling, my favourite colour is grey and it will put me in gaol as I run through my tyre collection).
I'm trying to think how an interrupt driven/loop driven system would have the ability to process an analogue signal and break down the frequency components without using DSP and large buffers to store the sample after each spark - I see no DSP opcodes in there.
It would probably pass through a filter that blocked all frequencies but the range in the specific map.. and do it sequentially until it made it through all of them.. considering the speed of the ECU I suppose its "fast enough" to get acceptable results..
And their probably not DSP routines, but signal traps on different inputs.. this would allow the ecu to quickly cycle through each range and test it.. Its simple enough to have several filters to attenuate the signal for each specific range and not have to do it programmatically.
Hi
have a look at post 14, it links to a document about knock detection, where the document details knock filtering, analouge and digital. Might be of some help determining how the ECU filters knock.
Knock thread
Also here Tom Collins makes a brief metion of how the ECU+ does its knock detection, the link above comes from this thread
ECU+ knock
MB
Knock thread
ECU+ knock
MB
